I have a lot of movies that need encoding to dvd format. They are either vcd/svcd (in .bin/.cue format w/ daemon tool immulation - spelling?), or avi (divx/xvid). I was looking for a tool that was all in one and found DvdSanta. It seemed to yield the best quality amongst all the programs that I tried. I did notice something though. Programs like TmpGenc -authoring advertised that it would make a "DVD compliant mpg". Other programs like DvdSanta made .vob files. I really prefer to have .vob files since that's what you get in the stores. Am I right in feeling this way? What is the difference between .vob files and dvd compliant mpegs? Will the amount of dvd players that play .vob files (duh - all of them) equal the amount af dvd players that play dvd compliant mpegs? Any help would be greatly appreciated!!![/b]
Closed Thread
Results 1 to 19 of 19
Nice try. BOLD doesn't work in titles.
Originally Posted by Dilemma
VOB is a DVD-Video formatted file made from compliant MPEG-1 or MPEG-2 video, and compliant AC3, DTS, PCM, MP2 audio. VOBs can also have subtitles and other information in them. They are more than just MPEG, but MPEG is in there.
Encoders only make MPEG files.
DVD Santa is some all-in-one tool that does it all. And not all that hot either, though it works. It's not just an encoder.Want my help? Ask here! (not via PM!)
Yeh, I understand all of that (Maybe I didn't word it properly)but, that still doesn't answer my question........... Is a DVD that has a standard compliant mpeg-2 the same as having one authored to have .vob files? In other words.....Can I convert with mybatchencoder and burn w/ nero and it will play in all dvd players or do i need to author first?
only_emo_kidGuest
u take an mpeg2 and burn it with nero as a dvd disc, put it back in ur dvd reader and it'll show .vob's on the disk
VOB is authored MPEG-2. Some DVD players can play raw MPEG-2, most require VOBs. Check your DVD palyer at https://www.videohelp.com/dvdplayers to see if it plays MPEGISO or DVD-MPEGISO. If not, you must author, simple as that. I suspect that mybatchencoder authorsw for you, so in that sense, then you're burning IFOs, BUPs and VOBs with Nero, so yes, it is the same.
Can someone please yellow card this guy for a pointless thread title, too ?If in doubt, Google it.
Originally Posted by only_emo_kid
That's the "problem" with using Nero - you lose sight of exactly what it is doing. I was the same with VCDs - at the time I didn't realise that Nero was authoring and burning for me in one (it wasn't re-encoding, I made sure of that) and it meant that when I made the switch to DVDs, all of a sudden this concept of authoring was foreign because I didn't realise that Nero had been doing it for me all along with VCDs.
Originally Posted by pijetro
quite a handy thread to keep bookmarked, that one
1. Question...
2. Answer...
3. (ignores answer) .. Question... again..
so ... maybe "NO-ONE" can answer it?
I give up.Want my help? Ask here! (not via PM!)
Originally Posted by lordsmurfIf in doubt, Google it.
Originally Posted by bugster
(1) The first place I would bet that you might have heard this is in the signature of a forum regular (no surprise there)
(2) The second place I would bet that you might have heard this is the webpage where said forum regular in (1) stole it from in the first placeIf in doubt, Google it.
Let me break this down in simple language for the original poster.
See, you start with magic juju flowers. You use the special magic juju flower ritual to change those magic juju flowers into magic juju juice.
But you can't DRINK the magic juju juice directly from the bowl. You need to put it into special magic juju cups.
If you don't put it into the magic juju cups, you can't drink it.
Are you following me here?
VOB is a container for MPG and all the other assets required for playback (multiple audio, subtitles, menus, etc). The IFO file contains information that tells the player what is in the VOBs.
Some players can play raw MPG files, but relatively few. Even on the ones that do you won't see menus, subtitles, or multiple audio streams. A raw MPG is definately not the same as a VOB.
If you want to make a DVD that will play on any player, you need to use authoring software to put the VOB container and associated IFO files around the MPG.
Hope this helps.
Happy Holidays!
RogThere are many ways to measure success. You just have to find your own yardstick.
Thanks a lot guys. You answered my question. I really appreciate it. However, I noticed with DvdSanta after encoding I get blocks in dark places of the movie. This is uneceptable. I now use Tmpgenc to encode to dvd-compliant mpeg. Now I have a second question. I need a program that will batch author several groups of files (each group contains two dvd-compliant mpegs) with really good video quality. I don't need menus. In fact, I tried GUI for dvdauthor and I couldn't figure out how to not use menus. Any help will be greatly appreciated. Thanks in advance.
-Oh by the way. This is a key................
1.) Quality is a must.
2.) It must be able to do two files into one dvd.......not all files into one dvd.
3.) I must be able to batch author.
4.) And, I dont care how long it takes.
5.) And all files must be dvd-compliant.
Thanks gentlemen.
Do one at a time.
And DO NOT cross-post:
https://www.videohelp.com/forum/viewtopic.php?t=248994
One is enough.Want my help? Ask here! (not via PM!)
FREEWARE for batch, menu-less authoring of DVDs
By nharikrishna in forum Authoring (DVD)Replies: 6Last Post: 11th Oct 2011, 04:00 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:16 -
How to Batch Process Using Avidemux? Or Batch Processing H264 .m2ts or .ts?
By forgotpassword in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 00:00 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 17:04 -
DVD Authoring software with Batch author?
By love2learn in forum Authoring (DVD)Replies: 6Last Post: 16th Aug 2007, 09:20
