i have got 2 avi files that i converted to dvd using this guide
http://www.dvd-guides.com/content/view/73/59/
i have sucessfully converted the files to .vob (2 files in total) but when i come to make the video/audio ts folders using TMPGEnc DVD Author i am told the combined bitrate is too high, the bitrate has to be 9848kbps for the dvd to work correctly is there any way to change this without having to convert the files again?
Hello,
Usually you can just click ignore and it will continue with no problems.
Just complete the process and use a rewritable disc to test it. You should have no problem at all.
Please note though that if you pushed the bitrate up too high then you may experience playback problems though depending on just HOW high the bitrate is it might ... stress might ... only be noticeable on some DVD players instead of all ... but if it is WAY too high then just about any DVD player will have issues with playback.
It's best not to push the video bitrate above 8000kbps and if you are using PCM audio keep the video bitrate at 7500kbps to be safe.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Flash video total bitrate
By Abstract40 in forum Video Streaming DownloadingReplies: 7Last Post: 28th Oct 2010, 11:35 -
TMPGEnc "clip total bitrate too high for a DVD-Video" issue
By dread in forum Authoring (DVD)Replies: 7Last Post: 26th Oct 2010, 15:34 -
TMPGEnc says "clip total bitrate is too high for a DVD-Video" but it's not?
By sasuweh in forum Authoring (DVD)Replies: 24Last Post: 30th Sep 2010, 03:17 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17
