What's the quickest way to convert a .vob file with a fps of 23.98 to 29.97? I was going to use TMPGEnc but it doesn't support .vob files.
Results 1 to 13 of 13
Run Like You Stole Something
You don't need to. If it is a .vob, it is DVD compliant, so it will be 23.97fps with 3:2 pulldown. This means it will be played back at 29.97fps by repeating certain fields. This is common and is the way film (24fps) is played on NTSC.Originally Posted by vbguru_12000
Use TmpGenc, mpeg tools. Demux it to .m2v and audio (.ac3 probably) add them seperatley to DVD Lab. If it will not accept the .m2v (with the same error), you can add pulldown to it (the .m2v) with pulldown.exe. I think there is also a GUI for it if you are not familiar with commandline apps.
Ok, it let's me add the .m2v file, however, it won't let me add the ac3 file. It says it doesn't start with the correct ac3 header. It then asks if I want to let DVD-Lab try and fix it, so I say yes. It then says it was fixed but so many bytes were removed. Then it comes up and says it's the wrong frequency and can't be added. Any ideas what I did wrong?
Run Like You Stole Something -
it has to be 48khz sample rate , not 44.1
Nm, got it, I'll let you know if the DVD comes out ok. thanks for all your help.
Where did you get a .vob file, with ac3 audio at 44.1khz?
I have never seen such a thing
When I do this, the audio and video are out of sync, and get worse and worse as the video progresses. It's as if the audio is going to slow, that, or the video is going to fast.Originally Posted by bugsterRun Like You Stole Something
And have you resampled the audio to 48khz. If so, how did you do it/what tools and settings. Is the original audio, when de-muxed, the same length as the video or is it just the resampled audio that is the incorrect length?
I was originally using Simple De-multiplex which was outputting a 44kHz file. I then used the De-multiplex which outputed 48.
When I go to play the two files, the video is shown to have a length of 13 mins, and the audio a length of 42 min. 42 mins is the actual length of the .vob file. Also, if I let the video run, it will play all the way through.Run Like You Stole Something -
That sound like the vob may be corrupted/invalid in some way around the 13 minute mark. Being able to play it is no guarantee that it is completley correct as players tend to skip over/ignore quite a lot of errors.Originally Posted by vbguru_12000
I am sure there are tools that can attept to fix this but can't think what they are at the moment
, maybe re-jig. Take a look in the tools section or maybe someone else can suggest something to help.
Best framerate conversion? (eg: 23.97 to 30 fps to avoid judder)
By ionone in forum Video ConversionReplies: 16Last Post: 12th Mar 2014, 08:56 -
Framerate conversion (again sorry) 60p to 25p this time
By Panash in forum Video ConversionReplies: 5Last Post: 2nd Jan 2010, 18:32 -
Framerate Conversion
By rackball in forum Video ConversionReplies: 10Last Post: 11th Aug 2008, 05:04 -
Changing the framerate during conversion
By 2nickelstripper in forum Video ConversionReplies: 2Last Post: 7th Dec 2007, 08:46 -
Audio framerate conversion?
By pYShTr in forum AudioReplies: 2Last Post: 28th Jun 2007, 12:05
