I just purchased a Dell 2005fpw monitor and was wondering what the best way to watch TV on it would be. I was thinking about either a ViewSonic VB50HRTV TV tuner module or a digital cable box. I am not sure if the viewsonic box will support widescreen resolutions because the website says that max resolution is 1024x768. I think that it might just put bars on the side of the screen, but im not sure. I will have comcast digital cable, but I am not sure what boxes would work with it or if I would need to do anything to get it to work. I also had a quick HDTV question, the max resolution on that monitor is 1680x1050 would it be able to properly display HDTV if not what would it need to support? Progressive scan?
Thanks for the help
Dan
Well first, this not a HDTV it's a RGB computer monitor. The Viewsonic box will get you a basic TV tuner and S-Video in from a cable box or game console. You would get more functionality with a ATI All in Wonder card in your computer.Originally Posted by danrock
If you can get over the air HDTV the ATI HDTV wonder tuner would put a scaled HDTV image on your screen (1920x1080 downscaled to 1680) but it won't work with a Comcast HDTV cable tuner.
To hook that monitor to a Comcast HDTV tuner you would need a transcoder box like this
http://www.ramelectronics.net/html/kd-ctca2.htm
but your monitor can't handle 1920x1080 interlaced in and that is all the normal Comcast HD box puts out (1080i). Talk to the transcoder company. Maybe they have a solution.
Lcd Tv as monitor
By alldonein in forum ComputerReplies: 2Last Post: 10th Jan 2010, 15:46 -
LCD TV vs. LCD Monitor for PC gaming
By Xenos80 in forum ComputerReplies: 6Last Post: 13th Feb 2009, 00:01 -
Displaying Photos on an LCD Monitor or LCD TV
By jbsiegel in forum DVB / IPTVReplies: 3Last Post: 25th Sep 2007, 13:29 -
Selecting a LCD Monitor?
By Brosco in forum ComputerReplies: 12Last Post: 6th Sep 2007, 03:03 -
Help on a LCD Monitor
By wasabiboys in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 05:58
