Has anyone else encounters lines in rental DVD's when they are zoomed to either 1X or 2X? It only seems to occur when the aspcet ratio of the DVDRHD04 is set to either 4:3 Ltter box or 4:3 Pan and scan. Lines do not appear when ratio is set to 16:9 Widescreen. Thanks
Sorry, haven't checked for that.
But while we're on the subject, anyone experience an over sensitive remote with this unit? I'm continually getting two presses each time I press a button once.I don't have a bad attitude...
Life has a bad attitude! -
I have that happen with the remote all the time. Seems to happen more often when I am trying to edit something.
Cool! I thought it was just me. Thanks for the post.But while we're on the subject, anyone experience an over sensitive remote with this unit? I'm continually getting two presses each time I press a button once.
Could those be scan lines on the tv? You may not nitice them until zoomed in.Originally Posted by tshows
Is your player interlaced or progressive? -
I don't beleive they are scan line. When zoomed to 1X there are usually 4 or 5 lines a few inches apart on the screen at 2X there is usuallu on 1 line a couple of inched from the bottom of the screen. The recorder is interlaced. I am wondering if this has anything to do with the 1191 version of the firmware. I did notice the line on 1185 version.but I may have just overlooked them. In some sceens they are not noticeable.
Ilo DVDR04
By 2003 Hayabusa in forum Newbie / General discussionsReplies: 4Last Post: 2nd Sep 2010, 14:48 -
Need files to update ILO DVDR05/ZU cant find anywhere
By strbyz1 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 22nd Aug 2009, 21:48 -
Ilo DVDR04 replacement drive
By emyly7 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 21st Aug 2009, 03:12 -
ILo dvd recorder not cooperating
By jhayes in forum DVD & Blu-ray RecordersReplies: 9Last Post: 9th Dec 2007, 10:06 -
Feeding ilo DVDR05 output directly to PC, is it possible?
By superspeedfreek in forum DVD & Blu-ray RecordersReplies: 3Last Post: 4th Jun 2007, 12:43
