  1. Hello,
    I have a long .aiff (almost one hour) that I want to break into 6 individual pieces ( so that I can forward to certain parts without using FF button forever) I dont care were the breaks are, just that they are there more or less evenly spaced. I dont have QT PRO. I use osx 10.2.8
    Any suggestions for a app to use that would work and is simple to use?
    thanks
    Bernie
    Dec 2003
    Eugene, Oregon
    If you have the full version of Toast 5 or 6 you can use CD SpinDoctor to do this. You also could use iMovie. I like Sound Studio. You could go to http://www.versiontracker.com and search for audio applications. Everything works with .aiff.
  3. Hello,
    I have full Toast T. and tried SpinDoc 2. It would not let me import the .aiff file that was generated by WireTap. I tried Imovie but it seems complicated .....
    Bernie
  4. ok,
    Thanks Fro Sound Studio worked SWEEEEET!
    Bernie
