i need a mobo, the bnest intel chipset, no onbaord graphics or sound, at least 6 pci slots, ddr ram space up to 2gb 800+ fsb hyper threading technollogy...all able to go into this case.... http://www.newegg.com/app/viewproductdesc.asp?description=11-133-133&DEPA=0 im looking for performance and speed and dont worry about the price, also, make sure it can handle atleast a p4 3.4 chip...holla back.
Results 1 to 11 of 11
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
any where else anybody
875 is still considered to be the best Intel chipset including the 9xx chipsets. If you don't need PCI-E then I'd recommend the Asus P4C800 (either the Deluxe or -E Deluxe).
FB-DIMM are the real cause of global warming -
6 PCI slots? What are you putting in all those?
Nothing can stop me now, 'cause I don't care anymore. -
i have my reasons
I don't mean to pry, just wanted to know if any of those functions can be combined and the number of cards can be reduced. 6 PCI slots is quite a bit for today's motherboards.
My HTPC is has 6 PCI slots and they're all full
sorry if i sounded abrasive, i didn't mean it, but yah, i have alot of stuff i use so i owuld like to put all of them in one big case, all running at once..holla baack
You do know that case has NO power supply. You'll have to buy one.
If you have 6 PCI devices, 400W Should be absolute MINIMUM to buy, such as this:
http://www.newegg.com/app/viewproductdesc.asp?description=17-159-023&DEPA=0
BTW, does it have to be an Intel ? I've been building P4 3.0s and AMD 64 3200 machines for the past month, and the AMD is faster, plus it runs cooler - much cooler than the P4. It's a great chip and a great price. Consider it. -
i want it to be intel, but ive heard what you rsaying before, can you recomend a combo for both chips
more then 1 show after authoring?
By Desert Flame in forum Authoring (DVD)Replies: 5Last Post: 15th Aug 2009, 18:01 -
I'd watch this new TV show!
By zzyzzx in forum Off topicReplies: 2Last Post: 8th Apr 2009, 15:12 -
Your computers. Show them to me.
By Faustus in forum Off topicReplies: 29Last Post: 20th Jul 2008, 12:43 -
Show Us Your Menus!
By p_l in forum Authoring (DVD)Replies: 47Last Post: 16th Apr 2008, 01:13 -
Have you ever been to a car show?
By yoda313 in forum PollsReplies: 20Last Post: 22nd Jan 2008, 12:48
