  1. I use DVD Shrink 3.2...
    Is there better software out there?
    I burn with DVD DeCrypter.
    thanks and peace,
    jay
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Occasionally there's movies that DVDShrink's ripping engine chokes on, that DVDDecrypter and/or smartripper have greater success with. To overcome this problem entirely, I use DVDDecrypter to rip every time and feed its output into DVDShrink off my hard drive. Logically, DVDShrink should work faster when fed from your hard drive as well.
    If in doubt, Google it.
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    This a list of the most common rippers:
    https://www.videohelp.com/tools?s=7#7
    Personally I've always used dvdshrink and never had complaints about it :P
    Kevin
  4. Member northcat_8's Avatar
    Mar 2003
    Chit, IDK I'm following you
    Yea...what Jimmalenko said.
    DVD Decrytper to rip and Burn
    Shrink or IC7 to shrink it (only read from HD, only write to HD)
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    ripping is not dvd authoring. moving you.
