So I have alway been under the impression that when naming dvd's they had to be in a format of all caps with underscores between any words instead of spaces. Recently got a movie on dvd and the title was in upper and lower case characters with spaces seperating the words. Is this ok or should I change the name to all caps with underscores, thanks.
Results 1 to 10 of 10
If the Thunder don't get you,
the Lighting will. -
Apparently when DVD players that played burned discs first became available, a few of them wouldnt play discs with titles not in caps. I personally have never run into such a player and always author my discs with mixed case characters, spaces, and sometimes a really long name. All play fine.
I always leave the same name as the original (which can include lowercase, spaces, odd characters, etc.), and I've never run into any problems playing them back on any players. YMMV
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
I always convert DVD names to my format, because they generally have stupid names. For example, seasons 1 through 3 of CSI all get the name DVD_VIDEO or something like that. For every disc. Changing it to CSI_S1_D3 or whatever makes it much more manageable. I name all dual layer DVDs with lowercase and spaces so I know I have to shrink them, and then I never get confused.
If it isn't broken, take it apart and find out why.
blog: deadsierra -
Yeah, forgot about those. I usually change DVD_VIDEO and UNDEFINED to something a bit more descriptive...
How do people miss that sort of thing? If you were creating a master DVD, wouldn't you actually check it to see if it was right?
blog: deadsierra -
Sloppy authors.
I always make sure my titles are correct. I've never had a client that had a problem with capitals and underscores.
DVD are ISO/UDF hybrid so the ISO session will have all caps and underscores. The UDF session can be anything. If you burn a disc in Toast for example and name the DVD "DVD Video", the UDF session will be "DVD Video" and the ISO session will be "DVD_VIDEO". The Mac always mounts the UDF session. The DVD player users the ISO session.
If you get info on the DVD in Toast one can see the difference in session names.
It would even be possible to name the UDF and ISO session different if the authoring application allowed it. As long as the ISO session has the correct name, a DVD player shouldn't have a problem. -
According to the spec, DVD players (incl. hardware) are expected to use the UDF volume. Many older players didn't for economical reasons (skimping), but this should improve with newer players.Originally Posted by chikanakan
Scott -
Thanks for that explanation. Very illuminating!Originally Posted by chikanakan
Default naming of captured clips in Vegas Movie Studio 10
By Medwynd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th May 2011, 17:18 -
Re-Naming AVI Files
By Naquada in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2010, 01:39 -
Output file naming in Super Build .38 for .VOB files
By Duwgati in forum Video ConversionReplies: 0Last Post: 2nd Jun 2010, 03:10 -
The naming of Hard drives & Burners on WINDOWS VISTA
By orfajackson in forum ComputerReplies: 2Last Post: 3rd Jun 2009, 14:00 -
Problem with naming DVD's
By KamilATL in forum Newbie / General discussionsReplies: 1Last Post: 28th Dec 2007, 14:07
