just began shopping for a dvd recorder. i'm looking at buying one of these:
pioneer DVR-520HS
jvc DR-MH30
sony RDR-HX900
any suggestions as to which one? i need hdd, 4 mode recording, high speed dubbing and firewire in/out. dual-layer would be nice too. the pioneer seems to fit this best, but i'm not certain about some of the features.
Results 1 to 18 of 18
All good choices.
JVC would be my pick.Want my help? Ask here! (not via PM!)
Just to keep things up in the air, I love my Pioneer 510 and recommed the 520 highly. I compared its features with the Sony when I bought it and concluded the Pioneer was the better choice.
Originally Posted by statas
I have two Pioneer recorders. The 210s (no HDD or DL) & the 420H-s (no DV or DL). Both have been flawless so far. I'm sure the 420H-s (no DL) will fit your needs. I don't know of any Desktop unit with DL, yet.
Just bought the JVC MH30 for myself for x-mas. Came yesterday. have not test drove it yet.
I think I would go Pioneer then JVC for my choices to replace my Philips should it die. The only reason I say it really is because a friend in Australia bought one....sent me a DVDR from it....and it reacted perfectly to all of my software choices.
Just my opinion.... -
thanks for the comments.
i only wish i knew when the pioneer recorder will include dual layer burning. -
I would not get a hard-on for dual-layer just yet. If it's anything like PC burning (and it always is), it's got a long way to go before it works decently and is affordable.
Cheapest I've seen are 7 bucks a pop for Riteks. I think I'll wait another year...
Still happy with my 4x Nec. -
For those of you that are supporting the Panasonics, have you observed 'poor video quality' from the 510H or 520H as the "review" claimed??
I found the Pioneer to be decent.
I've heard the Panasonic referred to as a Panachronic by a few people..
Originally Posted by H2OSkier
I bought a JVC DR-MH30s recorder and it offers super quality picture, many editing features and a easy to use remote. The prices are less than the other models. $585 with shipping from any NY video store
Sources for high-end VCRs considered
By sanlyn in forum Capturing and VCRReplies: 0Last Post: 29th Jan 2012, 08:57 -
low end quadro is 5 times faster than high end gaming card
By deadrats in forum ComputerReplies: 4Last Post: 7th Apr 2011, 15:42 -
Software Encoding on High-End System
By tbradyjd in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2010, 21:36 -
DVD Audio Rip Issue (Muddled High End)
By RKelly in forum AudioReplies: 4Last Post: 28th Nov 2009, 13:38 -
Use DVD recorder to record to end of video_ts files
By aeafisme23 in forum Authoring (DVD)Replies: 1Last Post: 4th May 2008, 17:53
