After processing a DV AVI in CCE 2.67 SP, I end up with the following 3 files:
*.mpa, *.mpv, *.vaf
My dumb question(s): what do I do now? What progs open the mpv files? IOW, can I see the results of my CCE compression?
Help me understand
Many thanks ~ John
Hi-
Right-Click->Open With, and then see if any of your current players will open it. I use Media Player Classic (MPC).
What do you do now? I'm in NTSC land, so next I usually run Pulldown.exe to create a 29.97fps .m2v, and then use that in my DVD authoring app of choice. -
mpa=audio, mpv (a.k.a m2v)=video
Next step is (like manono says) to run the mpv thru pulldown, or just author. The vaf is some internal CCE file.
/Mats -
Rename the .mpv to .m2v (some authorers acccept .mpv as do some media players).
The mpa is .mp2 audio
.vaf is the 'first' pass video information file so it can be safely deleted AFTER the mpv is created.
Only use pulldown.exe if the source was 23.97fps.
Slap the .mpv and mpa into your authorer and away you go. -
Thanks for the great info folks. I've got that bit sorted now, with your help.
I was trying to import the respective CCE files back into an EDITING prog, rather than an AUTHORING prog. Of course without success.
Ach! So much to learn!
John
Probably a dumb burning question
By neroguy in forum Newbie / General discussionsReplies: 14Last Post: 7th May 2011, 04:34 -
Dumb PS3 Question
By wulf109 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Feb 2009, 07:56 -
Dumb PS3 Question
By wulf109 in forum Off topicReplies: 2Last Post: 3rd Feb 2009, 22:36 -
Really dumb USB 1.1 Question
By ahhaa in forum ComputerReplies: 4Last Post: 1st Jan 2009, 15:50 -
Dumb question about 768p
By winterwolfes in forum DVB / IPTVReplies: 28Last Post: 2nd Jan 2008, 16:50
