Hi Friends,
I have a problem here. I am using nero ac3 plug-in to convert a stereo wave file but I am going wrong some where that when I select 3/2 with LFE support i get only 2 channel audio
yesterday accidently I re-encoded the same file (ac3- 2 ch) and my amp started showing it as 5.1 but with no sound from SL, SR and LFE
What is the correct setting to use the plug-in ?
Also I need to know how to burn a 6 ch wav file (single file) with nero.I have multi-channel plug in but i get error. Can it be burnt as normal cda file and my dvd player (samsung e138a) play it as mulyi-channel?
You can't burn a 6ch PCM file to cd-audio standard, as that requires 44100Hz-16bit-2ch PCM.
Sorry, I had to go see about a girl -
Thanks for your reply.
But then what format should I use?
My dvd player supports mp3, cda and wma but does not support standalone ac3. Also it does not play 5.1 wma and I want to make a 5.1 ch file. -
Hello,
Besweet can output to 5.1 wav. You can burn that as an audio 5.1 cd. I've done it successfully before.
The besweet website has a ton of info and tools on audio conversions. It has a little bit of a high learning curve but well worth it for what you're talking about.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
2 Channel AC3 25fps to 24fps eac3to problem
By Pegbeard in forum AudioReplies: 23Last Post: 13th Apr 2010, 20:41 -
Multi-Channel sound on 4350 not working 100%, (ONLY 2-channel)
By THX-UltraII in forum AudioReplies: 1Last Post: 20th Feb 2009, 05:35 -
any way to capture 2 channel audio when VCR only has white plug?
By cduval04 in forum Capturing and VCRReplies: 6Last Post: 20th Jan 2008, 16:55 -
Properly encoding multi-channel AC-3 to multi-channel AAC
By PuzZLeR in forum AudioReplies: 1Last Post: 15th Nov 2007, 14:07 -
Convert MPEG-TS 5 channel AC3 to h264 x264 sound problem
By TequilaErik in forum ffmpegX general discussionReplies: 0Last Post: 16th Jul 2007, 19:41
