I've burned a vcd from VideoWave 5 and the quality is poor. Is the Nero 5 a better program for vcd or is it a media problem. Easy Creator 5 quality is a little better. I would like to have the vcd's close to VHS
The actual burning program shouldn't effect the quality, other then it will either work (play) or it won't. It's the video converstion step(s) that define the quality.
What do you mean by converstion steps that define quality.
<font size=-1>[ This Message was edited by: Dmsimm on 2001-11-30 00:31:20 ]</font> -
I was assuming you are taking a video file and converting it somehow to VCD format before burning it. I'm not familiar with VideoWave, so I don't know if that's a conversion program (I use TMPGEnc). If it's true VCD format, then the setting for things like resolution and bitrate are preset. But if you can use XVCD, you can adjust these settings to improve quality.
Where can I get the TMPGenc program. I'm wondering if the quality for a vcd would improve over the CD creator 5 and Videowave 5 programs. I have alot of blocks when I view the burned vcd.
burning software
By hardy in forum Newbie / General discussionsReplies: 8Last Post: 4th Sep 2011, 18:00 -
Best Burning Software
By bmoreravyns in forum Authoring (DVD)Replies: 32Last Post: 14th Oct 2008, 20:46 -
Best burning software???
By Eternal7331 in forum DVD RippingReplies: 8Last Post: 11th Oct 2007, 00:29 -
what burning software?
By dickdb in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 3rd Oct 2007, 17:48 -
burning software
By Cmonteith in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 19:07
