hey guy need help ok i have TMPGEnc 3.0 XPress
and when i open it. it cover the whole screen
on my pc so my question is is there a way to make
the prog smaller on my screen (gateway ev700)
beisde useing the Display Properties setting
to make it small ???? thanks
Results 1 to 11 of 11
no it not that it when i open it it to big (Screen) to pick what i want to do with the prog do you know what i mean like (OK, GOBACK ECT..) at the bottom of the prog
Originally Posted by anzimike -
This sounds like an issue of using a screen resolution below the minimum requrements for the particular program - I can't remember who it was, but someone here a week or two ago wanted the keyboard shortcuts for NeroVision Express, but could only use 640 X 480 and couldn't see the next, OK, Cancel etc. buttons. What is your screen resolution ?
If in doubt, Google it. -
OK - I found the thread I was talking about ...
https://www.videohelp.com/forum/viewtopic.php?t=247600
Does this sound basically like the problem you're experiencing ?If in doubt, Google it. -
I have the same problem. You can change the resolution in Appearance and Themes.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 16:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
