Thanks once again junkmalle for your in depth suggestion.
I'm visiting my son in law next week and will give that two cameras on one film a try. However, it still seems wierd that the clear picture you see which was obtained from his computer transfer AVI file, ended up a fuzzy AVI when the same film is transfered onto my computer.
I could not use the same film for clear and fuzzy for my examples as he had taken the film back with him.
Results 61 to 79 of 79
@ meridklt / All...
I think a summary of where we're at is warranted, to bring together all that's been tried and the results received.
meridklt - Would you oblige by listing all the combinations of cameras / cables / PCs that you've tried and their associated results.
Also, a list of what actions you've taken (e.g. swapping the card to a different PCI slot) would be useful too.
From this summary, we may see something else to ry or be able to identify the (likely) problem / candidate.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Hello daamon,
Some of this information regarding my son in laws side of things will not be available until Monday (he works away from home).
So on Monday I shall be travelling to his home with my camera and will be able to do tests on his computer, and then on my own when I return home as junkmalla suggested.
So I will make a full report here on Monday, so watch this space. -
Hi meridklt,
Combinations to try (just to take advantage of being there)...
Take a re-writeable CD with you (assuming he's got a CD writer).
1. Shoot the same footage at the same time - gives you comparable light levels.
2. Swap tapes over. Re-do 1.
3. Capture from both cams to your Son-In-Law's PC, to separate DV AVI clips. There should be four clips - 2 from each cam: before and after tape swap.
Label clips accordingly for your Son-In-Law's PC.
I'm gonna assume these are OK, based on previous posts.
4. Store the four DV AVIs from your Son-In-Law's PC on the CD-RW for comparison purposes.
5. Capture from both cams to your PC, to separate DV AVI clips. There should be four clips - 2 from each cam: before and after tape swap.
Label clips accordingly for your PC.
6. Capture from both cams to your PC using your Son-In-Law's firewirecable, to separate DV AVI clips. There should be four clips - 2 from each cam: before and after tape swap.
7. Review all clips. Post results here.
8. Drink a well earned pint.
If you want to enable recording via firewire to your DV cam, search for "enable DV-in" on Google. Similar searches may be necessary...
Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Originally Posted by meridklt
It just strikes me that with all of the suggestions and advice you have received, the problem should of been found.
Personally, I think you need to verify each individual step to see where it is tripping up. Starting with transfer in from your camcorder and without any other action, transfer out to another camcorder. As you would of done nothing, the transferred out video, when played on your TV should be identical to the origional. If this is true, then the transfer is not the problem.Have a nice Day -
Originally Posted by mikesbytes
Is all this straight forward? i.e Transfer from my camera into Premier 6.5 timeline (I'm new at Premier also), swap cameras over on firewire cable and tell Premier to put the Timeline on new camera. -
However, if it does accept input, this is how to do it in Premiere 6.0:
1. Start and save a new projerct.
2. Capture test clip in Premiere from desired camera.
3. Drag clip onto timeline.
4. Swap cameras at other end of firewire cable.
5. File -> Export Timeline -> Export to Tape...
6. Premiere controls the cam and you just click record in the Premiere window.
ANOTHER THING TO TRY, if your Son-In-Law is happy, is to swap over your firewire cards and record and review your DV AVIs then. Be sure to use both cams on each firewire card in each machine...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Many thanks for the further advice daamon.
I sure have a lot to do that day, as before any of this serious stuff takes place I'm taking my little grandson on his first railway journey. Then at journeys end we step off the train into Father Christmas's grotto. -
No problem.
Have fun on the train - oh, and if you video it, make sure to capture the footage on your Son-In-Law's PC!There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Hello all who have helped with my problem.
Problem is sorted, it was my capture card. Put mine into my son in laws computer and his captured AVI was poor and fuzzy. Put his capture card into my computer and captured AVi was clear without any fuzz.
So what make should I get (could not see a name on his and he does not know). -
Hi meridklt,
Get a generic one from www.eBuyer.co.uk - Good prices, good gear, good service. I used them all the time when I was in the UK.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Yeah, what canadatek said.
Like this one... It's got 3 external input ports, 34 reviews and scores 4.5 out of 5 - all for 9 quid.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Originally Posted by meridkltHave a nice Day
Originally Posted by mikebytes
To all who have helped me and any who are reading this Post, may I wish you and yours a happy Christmas. -
And a Merry Xmas and trouble-free video New Year to you too.
I think your Son-In-Law deserves a bottle of whiskey for allowing you to dismantle his PC based on the say-so of a stranger (albeit an English stranger) in Australia!!!
That link I gave you above (Posted: 21 Dec, 2004 10:16) will take you to a firewire card that'll do the job.
Daamon.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
meridklt,
If you have a choice, go for TI or NEC chipset firewire card. Avoid VIA chipset firewire cards. Struggled with my VIA chipset card until I get suggestion from daamon to uninstall and try another PCI slot.
Installed a NEC firewire for my brother last week. It was much easier.
Poor capture quality. How can I fix it?
By Caprica7 in forum Capturing and VCRReplies: 3Last Post: 23rd Jul 2011, 06:50 -
Poor Picture quality - need help!
By Martin747 in forum EditingReplies: 2Last Post: 26th Dec 2010, 12:00 -
Poor Burning Quality
By CindyLuB in forum DVD RippingReplies: 6Last Post: 17th Jul 2010, 20:41 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 19:23 -
Poor Quality
By Net_Bug in forum Capturing and VCRReplies: 3Last Post: 29th Mar 2008, 16:37
