I was plalning to make a widescreen xvcd and wonder what x what are the dimensions. Also will a widescreen XVCD be recognized by the player. (keeping in mind my player always takes XVCD/KVCD and i have tested it.
-Helghast
Results 1 to 10 of 10
widescreen has nothing to do with the frame size - it's all about Aspect Ratio
https://www.videohelp.com/xvcd.htm#tech
So you see that you have to stick to standard VCD frame sizes (352 * 240/288) for it to be a ..... wait for it ..... compliant XVCD (bit of a contradiction of terms IMO, but anyways ...)XVCD PAL
Video:
any kbit/sec MPEG-1 both variable and constant bitrate.
352 x 288 pixels
25 frames/second
Audio:
32-384 kbit/sec MPEG-1 Layer2
Extra:
Menus and chapters
Still pictures in 704x576,352x288
XVCD NTSC
Video:
352 x 240 pixels
29,97 frames/second
(23,976 frames/second NTSC Film)
Audio:
Extra:
Menus and chapters
Still pictures in 704x480,352x240
So just set your Aspect Ratio to 16:9 and everything else the same as VCD, maybe play with the bitrate or encoding method and you should be good to go.If in doubt, Google it. -
My understanding is that VCD/SVCD(X)-(K) do not support widescreen. You can encode it as widescreen but many DVD players will not play it widescreen,they will display full screen with improper A.R.
Is that ratio on my encoder software or dvd because the last xvcd i burnt even at widescreen mode the heads were a bit bit ie: tops chopped off.
Would be nice to see it properly though
-Helghast -
What do you use ?
tmpgenc can do this very easily. Others may require you to resize correctly in something like virtualdub first.Read my blog here.
--- sits huddled in a corner, rolling steel balls around in one hand and mumbling to himself "compliant XVCD, compliant XVCD".
Sorry, took me a second to get my mind right.
As Wulf stated, VCD does not support widescreen. That doesn't mean your particular player won't play it, though. -
so i just tell tmpgenc to make it 16:9 resolution, then will be bars back? I miss my bars :'(
Also how the hell can there be a compliant XVCD.... Its non compliant VCD's and anything that breaks the bounds of VCD is XVCD so how can there be a compliant XVCD when there are 100s of different combos + its not supposed to be compliant
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 09:24 -
How to fullfill a widescreen video (4:3) into a widescreen project (16:9)?
By coxanhvn in forum Newbie / General discussionsReplies: 8Last Post: 10th May 2011, 12:59 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 14:22 -
Convert Pseudo Widescreen to Proper Widescreen
By simonw2008 in forum Video ConversionReplies: 5Last Post: 5th Apr 2008, 21:57 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 23:15
