Hi, can anyone tell me the best software for changing the framesize of an AVI - if possible without losing too much off the sides would like to make it full screen
Thanks JT
Use a software player that can zooooom, like zoom player.
If you want to reconvert use virtualdub, add the resize filter. Make it 4:3(width/height = 1.333333) if you want it full screen, you must crop the borders if it is a widescreen movie. -
Virtualdub would be my recommendation too.
It *sounds like* you have a widescreen clip and would like to make it full screen which means that you're gonna lose a bit off the sides no matter what method you use in order to not "squash" the footage horizontally.If in doubt, Google it.
Increased picture quality with increased framesize (during transcode)..?
By Gew in forum Capturing and VCRReplies: 1Last Post: 31st Mar 2009, 11:04 -
framesize problem with Mov to DVD
By Burny in forum ffmpegX general discussionReplies: 5Last Post: 24th Mar 2008, 05:57
