Hi all!
I got problem calculate the right bitrate for my xvcd
I´m planing to make a xvcd (with standard res. and sound. only higher bitrate)And i´m going to use constant bitrate.
I was using vcdhelp.com cal. but the file gets too big!!over 700megs
I want 43 minutes on a 80min cd and maximum bitrate
what am i doing wrong???
the software and hardware i´m using is (tmpenc. nero, pioneer 343(dvd)
if somebodey got a template for a good xvcd that will work on my pioneer 434 you are free to send it to me!
regards,
Magnus
(Sweden)
On a 80 min xvcd you can fit near 800 MB so a file over a bit 700 MB will fit.
Why wont Nero accept my file beeing over 700megs? it tells me that my media (the 80min cd) is too smal to save the file?
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
Bit Rate
By shapper in forum Newbie / General discussionsReplies: 10Last Post: 2nd Jun 2008, 15:04 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48 -
the right bit rate
By nojee in forum Video ConversionReplies: 5Last Post: 10th Nov 2007, 04:00 -
Making 32-bit VFW-ACM codecs available to XP 64-bit Edition.
By gastorgrab in forum EditingReplies: 5Last Post: 19th Aug 2007, 12:12
