    Mar 2004
    Downtown Los Angeles
    I have a vob file, but I can only play it in VLC.
    Is there anyway I can find out if it's PAL or NTSC [24/25/30 frames] ?
    Is there a way to find this information out inside of VLC? or maybe another prog. that can read .vob files?
    Jun 2001
    Silver Spring, MD USA
    MPEG Info X will tell you what you wanna know, and more.
  3. Might be that the VOB got corrupted try and use MPEG Streamclip it might fix it, did it for me all the time
    Mar 2004
    actually, the VOB file isn't corrupt [in my case] it's just that I have a VOB file and can't tell if it's PAL or NTSC [since I can't see the frame rate information].
    Can DVD player give you this info?
    Mar 2004
    ... i wasn't able to find it on VT? [or on their old website]?
  6. You can try to change extension from .VOB to .mpg and open it in QuickTime...The hit command+i and you should get various info on your file....Note that you need MPEG2 component for QuickTime for that...
    Also MPlayer can give you the info on your .VOB...In the bottom right corner of MPlayer GUI is the little "i" button....Drop your .VOB on the play list, select it and click "i"...
  7. Hi
    Open your .VOB file with any hexa editor (hexedit is fine )
    look the byte at 0x0048
    if the byte is 4x, 5x 6x or 7x, your video is PAD
    if the byte is Cx, Dx, Ex or Fx, your video is NTSC
    if the byte is 00, unlucky, I will give you a other solution.
    Jérôme
    myDVDEdit, the DVD resource editor.
    myDVDEdit, l'éditeur de ressources du DVD.
    Jun 2001
    I cant seem to find it either. Send me a private message through this board with your e-mail address and I'll just send it to you when I get home this evening.
