I need to remake a DVD that consists of 6 30 minute episodes and extras.
I want the DVD to jump straight to the episode selection (bypassing all the trailers etc) and disable the main menu button. From this point I should be able to remove all extras and associated menus, but inlcude the 6 individual menus for each episode. I have been playing around with DVDRemake and PgcEdit but its looking pretty damn complicated. Where can I tell the DVD to go to a specific menu (in this case pgc11 : c1) when you insert the DVD? And if I keep all the menu/episode numbers the same, I should need to retitle anything, right?
Results 1 to 11 of 11
Sorry...forgot to add...
I want the disc to start playing the whole series of episodes (i.e. activate the Play All button from insertion) but have the episode menu as a backup. -
There are some guides on the homesite of dvdremake, try here;
http://www.dimadsoft.com/dvdremake/info.php -
Originally Posted by SKiNFreak
There is (was) no freeware version of the DvdReMake. There are registered copies and there are demos (can't export). Whatever you may have is not a freeware
For the task you've described Pro gudes will probably be more appropriate: http://www.dimadsoft.com/dvdremakepro/info.phphttp://www.dimadsoft.com - home of DvdReMake and MenuEdit tools -
Hmmm...I downloaded a "freeware" version from somewhere.....I better shut up now and count my blessings....
I cannot get it to do what I want at all. I think the problem is that all the discs contents are all part of one Title Set. The extras are the first sections followed by the episodes. The episode menus precede the episode selection etc..... a right pain! ARGH!
Best DVD ripping tool?
By bkkfrank in forum DVD RippingReplies: 4Last Post: 6th Oct 2009, 12:54 -
Which DVD Authoring Tool ?
By Leo48 in forum Authoring (DVD)Replies: 5Last Post: 1st May 2008, 15:37 -
Remaking Special Edition: Inserting Deleted Scenes
By snipper_cr in forum EditingReplies: 0Last Post: 16th Dec 2007, 13:45 -
Best DV to DVD conversion tool
By whenloverageswild in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 24Last Post: 2nd Nov 2007, 00:50 -
Which tool from AVC HD to DVD?
By CineManno in forum Video ConversionReplies: 14Last Post: 2nd Oct 2007, 01:45
