I am capuring DV into an .AVI file. Should I first convert to an MPEG and edit or edit and then convert? Does my decision affect what editing tool I can use? What are the best .AVI editors and the bet MPEG editors?
This newbie thanks you.
Edit in AVI format, try Virtualdub.
He's a liar and a murderer, and I say that with all due respect. -
edit in avi (DV) , see tools on the left .... or do a search here ...
It is much easier to edit in AVI - a lot of people report synch problems if editing MPEG. Virtualdub is pretty easy to pick up, and as an added benefit it's also free. Once finished editing in virtualdub, you can then frameserve to your favorite MPEG encoder, either using virtualdub's frameserver, or by using AVISynth scripts and integrating the edits into your script. FulciLives' guide might be worth a read
If in doubt, Google it.
intermediary format for editing screencasts
By codemaster in forum EditingReplies: 6Last Post: 25th Dec 2011, 08:59 -
What format u recommend i convert to for editing?
By vannhat in forum EditingReplies: 4Last Post: 25th Nov 2010, 17:16 -
VLC Format Movie Editing Help
By helpmepls in forum Newbie / General discussionsReplies: 6Last Post: 30th Oct 2008, 17:58 -
recommend a video editing format
By contech in forum EditingReplies: 17Last Post: 12th May 2008, 15:39 -
Editing footage in MPEG-2 format
By RuckusVideo in forum EditingReplies: 6Last Post: 31st Jul 2007, 09:36
