  1. I was wondering if I can plug an external dvd writer with USB 2.0 cor into an older computer that has a 1.0 port. Will this cause problems
    JOE M
  2. Member Heywould3's Avatar
    Apr 2002
    always on the move
    just speeds.. it will run very slow.. usb 1 is 12mbs where 2 is 480mbs or there abouts.. so your burner will run very slow.. prolly 1xish
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    nope - no problems ..
    USB 2 is forty times faster than USB 1 also --
    USB sucks for dvd burning and capturing anyway ... 1 or 2
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Exactly. Usb 2.0 is BACKWARDS compatible with USB 1.0. The barrier - SPEED. It'll work but not as fast as a 2.0
    Kevin
  5. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Yeah should work at slow speed. Or convert to firewire and live in a better world.
  6. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    If it's your burner AND your computer, you're wasting performance using USB 1.1. The cheapest route to better performance is to install a USB2 card in the older PC. If it has PCI slots (anything with USB SHOULD), you can pick up a card for $30 at Staples.
    Nothing can stop me now, 'cause I don't care anymore.
  7. Member Conquest10's Avatar
    Chicago, IL
    With what Flaystus said, you can also get the cards that have both USB 2.0 and Firewire.
    His name was MackemX
  8. Member Soopafresh's Avatar
    Jan 2004
    http://www.newegg.com/app/ViewProductDesc.asp?description=15-106-004&depa=0
    Cheap, and I've installed several with 0 Problems
