    Dec 2002
    london
    Hi, I have some mpg2 files which I want to shorten before I burn them author them to DVD, but I don't want the authoring software to do it because it takes forever!
    So, is there a piece of software that will just allow me to chop off the start and end of the clips?
    thanks
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Tmpgenc can. go to file - mpeg tools - trim?? (I forgot the exact tab but it's the last one in mpeg tools).
    Then you can set the start and end points. There are other trimmers in the tools section found on the left <--------
    Kevin
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    you could just add a chapter also to the point you want the dvd to end and make that that the last chapter .....
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I author with TMPGEnc DVD Author and use it's Chapter Edit Cut tab to do this.
    Either that or you could use Womble MPEG-VCR, which is generally regarded as the best MPEG editor ATM.
    If in doubt, Google it.
  5. Member burnman99's Avatar
    Apr 2004
    Arkansas/USA
    Jimijames, AviDemux is an encoder that can trim your files. It's similar to Virtualdub, it's free, and you can find it here http://avidemux.sourceforge.net/
    Happy Holidays!
    Rog
    There are many ways to measure success. You just have to find your own yardstick.
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    he has mpeg files - not avi files
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Pays to read the question, doesn't it ?
