Hi Guys,
Can someone please help me with this. I have NEro 5.5.4 & have the OEM key with the software.What is happening is when i convert an .avi file to .mpg using TMPGEnc, NERO does not let me make a VCD. The Burn CD button is not highlighted. I have an Iomega External CD writer.I have tried Highlighting the File, The CD but still no luck
So what i did was I installed EZ CD Creator 5 platinum & it works fine but EZ CD does not let me create SVCD's so i need to switch to NERO. So please if some one can help me.I would appreciate.
Or if someone can tell me which burn software to use to burn SVCD`s I would appreciate it.
thanks
Use VCDImagerGUI to convert the mpg file to cue/bin.
After that, you burn the bin/cue file with FireBurner.
It works great!
All these available here in VCDHelp.
Fernando -
hello fgb,,
thanks for your reply. But will this CD after burning play on my VCD player. I have a grundig GDV-130 DVD Player.
thanks -
Hello
Can you burn an svcd from a bin/cue file using EZ CD Creator?
Thanks,
JCH -
You might try downloading another copy from the home sight. Make sure that you completely uninstall your current version before installing the newer version. And if that doesn't work...well, I'm not trying to encourage any illegality, but you might try and find a crack for it.
"I'm Batboy"
Frustrated trying to burn SVCD
By InfoSeek in forum Newbie / General discussionsReplies: 15Last Post: 8th Mar 2010, 20:34 -
Can I burn VCD or SVCD on DVD±R/W?
By Baldrick in forum Authoring (DVD)Replies: 111Last Post: 30th Aug 2008, 16:38 -
How to burn a SVCD onto a DVD?
By php111 in forum Authoring (VCD/SVCD)Replies: 9Last Post: 16th Oct 2007, 02:32 -
Freeware app to burn SVCD's?
By louv68 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 18th Jul 2007, 14:28 -
Xvid to svcd + burn...
By Crapozo in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2007, 05:07
