I posted here last week. Unfortunately the suggestion I got didn't work.
I am using the Nero software to author and burn after capturing with WinTV 2000.
My first effort, a month or so ago, went very well. However I am not having much luck in the here and now.
The problem is that I am now getting almost no audio. If I crank the TV I can barely hear it. I didn't have this problem with my first effort.
The suggestion on the previous post was to use TMGenc to encode. I tried that but the result was the same. Virtually no audio even though my source audio is plenty loud. Even upping the record volume to 167% didn't help.
If anyone is familiar with the Nero software perhaps you can point me to a setting that I am missing or something. I'm near the end of my rope.
Thanks in advance as always.
Dwayne
Dwayne,
I've just moved your thread into the Audio Forum.
I'm afraid I can't suggest anything for your problem - sorry.
Cobra -
What is this audio? PCM? Dolby digital? Mp2? something else? stereo or multichannel?
If it's stereo you can try opening it in a audio editor (Goldwave for example, but you could do it with besweet as well) and normalize to 100% (it may be just that).
If it's dolby 5.1 it gets trickier. You need an advanced audio editor and/or a dolby multichannel encoder, and you have to first normalize to 100% and if need be compress the dynamic range and re-encode.Sorry, I had to go see about a girl -
WinTV 2000? A Hauppage card? PVR1/2/350? Captured to mpg? If so, just author your mpg with some "real" authoring app (I use TMPGEnc DVD Author or DVD-Lab for this, so I don't have to demux...)
/Mats -
I am capturing to AVI with WinTV. The sound is fine the AVI file. Here's what's different:
The video I'm having issues with was captured from an 8mm camera with a single mono audio output. In order to fill both audio channels I split the single RCA output into two, and then combined in to one at the sound card with a y cable and a stereo adapter.
Perhaps this is the cause of my problem -- but again the sound on the card is fine.
Thanks again for all the help.
Confusion with DGIndex, AviSynth, VirtualDub and audio files
By fatcharlie in forum Newbie / General discussionsReplies: 10Last Post: 1st Mar 2011, 15:49 -
avi audio help/confusion??
By turbopwr in forum AudioReplies: 5Last Post: 2nd Mar 2010, 17:30 -
Digital audio confusion.
By Xylob the Destroyer in forum Off topicReplies: 3Last Post: 18th Apr 2009, 09:15 -
audio track confusion
By simdesire in forum Video ConversionReplies: 2Last Post: 6th Jun 2008, 13:15 -
Audio passthrouth confusion.
By rickeo in forum ffmpegX general discussionReplies: 0Last Post: 29th Feb 2008, 13:25
