Hi guys,
Before buying the Canopus Procoder I need to ask if it's able to convert NTSC to PAL.
I have a NTSC digital camcorder and want to write a DVD for overseas. When I capture the movie it's NTSC. What I bassicaly need is a software able to make an Mpeg2 PAL, for DVD authoring and eventualy to be able to burn a PAL DVD.
When capturing, looks like I am able to set the capture to PAL. I didn't try this yet. Can this work ? (with Adobe Premiere).
Anyone, any help will be appreciated.
Thanks a lot guys.
Results 1 to 16 of 16
procoder does an excellent job of converting ntsc to pal
Great. Thanks.
So it's worth to buy it.
How about that confusion with the possible setup of the capture directly in PAL ? Is this really possible ?
Thanks a lot for the fast reply. -
Progressive?Originally Posted by BJ_M
Interlaced?
Both?
interlaced (set the fields opposite on the output what they were on the input - tip), i get excellent results ..
progressive -- procoder uses the time method instead of creating new frames (speeds up 23.976 to 25) , though this is adjustable in options .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I'm still on 1.something.
Still good? Or 2.0 only?Want my help? Ask here! (not via PM!)
for conversion of standards , 2.0 for sure ..
1.x doesnt cut it for that purpose .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
dont think so
OK, I discovered Adobe Mainconcept now.
Which one is better for NTSC to PAL convertion ? -
canopus
Does procorder express also convert the ac3 audio framerate? Or does this need to be done seperately (Besweet or ffmpeggui)? I ask because I currently do my rare pal/ntsc conversions with TMPGEnc express 3.0 and ac3 plug-in all in one step, but would like higher quality and speed for similar price. And if so does it retain 5.1 or down convert to 2.0 like TMPGEnc express? Thanks in advance!
Canopus Procoder Help
By spliffy in forum Video ConversionReplies: 3Last Post: 15th Nov 2008, 03:07 -
Encoding progressive NTSC material with Canopus Procoder 1.5?
By zee944 in forum Video ConversionReplies: 8Last Post: 13th Oct 2008, 07:56 -
Canopus Procoder Cropping
By spliffy in forum EditingReplies: 1Last Post: 20th Dec 2007, 21:25 -
Anybody tried Canopus ProCoder 3?
By cosmin in forum Video ConversionReplies: 1Last Post: 16th Oct 2007, 21:25 -
Convert PAL 16x9 DVD to NTSC DVD w/ Procoder - Less Image-More Borders Why?
By tubularusa in forum DVD RippingReplies: 15Last Post: 5th Aug 2007, 01:26
