DVB
    Dec 2002
    london
    Hi there, I write this as a very confused man. Please help.
    I have a Haupppauge Nova-t TV card. I want to put recorded programs onto DVD.
    In the TV card software, the recording option is set to MPG (PS audio/video).
    When I try to author the mpg files (using TmpgeDVD Author) it takes hours!! What am I doing wrong.
    What do I need to do?
    Australia
    It could be the audio - DVD Author may be re-encoding it, this always slows it down.
    When you add the video to DVD Author does it have the 'Re-encoding settings:' ticked on the Audio Settings? If so, what format is your source audio?
    Dec 2002
    london
    No, the re encode setting is not tickedd.
    does it take same time to author other dvd mpg files with tmpgenc dvd author?
    are you using latest version?
