Im thinking of getting a new PC to encode xvid
it is optimized xvid for amd ?
Results 1 to 11 of 11
I don't have an answer to your question but having just built a new computer and having been a long time AMD user, I decided to go with a P4 this time and I like it much better than I did the AMD that I have been using for years.
For me anyway, my system is much more stable and is much faster.
Now I did upgrade from a AMD 2.2 (1.8 Ghz) to a P4 2.666 with a 533 FSB, so that is probably why the drastic speed difference but for $75 for Tower, MoBo, Processor and Video Card I couldn't turn it down. -
Read the benchmark test results...
https://www.videohelp.com/forum/viewtopic.php?t=248409 -
INTEL !
(real world stability)
AMD - better bang for the buck , but still hamstrung by some flaky chipsets to use with them (not always though) , latest smp amd systems are very stable , as are some amd64 systems i understand .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Pretty sure that most XviD developers run AMD CPU's or at least they used to. Koepi's XviD builds are ICL 7 optimised for all CPU's including AMD's.
I also have ICL 7.1 builds and gcc athlon-xp and tbirds builds.
Also XviD contains assembly for 3dnow, SSE2 and MMX. With older AMD chips you don't get the SSE2, but with the 64bit chips you do. -
The pirates and hackers that design the XVID codec undoubtedly have AMD chips.
But Intel chips will still encode ANY video codec faster than their equivalent AMD counterparts. *shrug* -
Pirates and hackers?
I wonder what a benchmark with say mencoder running 64bit would compare to a P4 running mencoder under a 32bit kernel? -
If you look at the benchmarks presented by anandtech, it appears that xvid is faster on AMD than Intel. I suspect if you compare on a $ to $ basis, AMD will be way ahead.
no - we have not found that to be the case at all .. intel is slightly more expensive, and for network rendering CGI , intel xeon 800fsb systems were slightly faster on some things , amd dual systems on others (both were quite stable) -- on single cpu systems, the prices were even closer and the intel system were generally more stable ..
it is a pointless debate - really ..
they are both pretty good systems now and it is good there are two systems to choice from as it keeps things progressing, and prices low .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Ex-AMD engineer rips AMD management
By deadrats in forum ComputerReplies: 0Last Post: 17th Oct 2011, 19:39 -
AMD up for sale?
By deadrats in forum ComputerReplies: 14Last Post: 19th Feb 2011, 22:17 -
AMD Phenom X4 9500 vs AMD Phenom II X3 710
By kenmo in forum ComputerReplies: 16Last Post: 1st Apr 2009, 21:03 -
AMD 64 4000+(1x2.4GHz) or AMD 64 X2 3800+ (2x2.0GHz)
By neomaine in forum ComputerReplies: 19Last Post: 13th Jul 2007, 11:24 -
AMD forums
By gmcman in forum Off topicReplies: 1Last Post: 9th May 2007, 22:27
