I just spent well over an hour using the search and reading faqs here and elsewhere and can't find info telling how to change burn speed from 8x to 4x.
Got some of the dreaded CMC 8x and so far out of 11 discs 3 have been coasters so thought I would try them at 4x.
On the last screen before burning, there is a selection for burn options, I think. It's the last button of the four on the right, including drive to write to, volume name, etc. Click on that, and select the speed you want. Mine always defaults to max, and I lower it to get it to work.
DvdShrink as such dosent burn disks it relies on Nero or dvd dycripter to do it.... Proberly better just to let shrink output the files as either iso or Video_Ts folder and use something else to burn.
In nero its the next ot last screen where you can change speed and its the same in dvd dycripter you can alter it from max to what ever you need.Not bothered by small problems...
Spend a night alone with a mosquito
Adjust Speed without Changing Pitch
By sickboy_xl in forum AudioReplies: 5Last Post: 8th Dec 2008, 11:17 -
Changing video speed with Nero Vision 5
By garin_c in forum Newbie / General discussionsReplies: 4Last Post: 21st Oct 2008, 10:12 -
Nero 7.5 changing .IFO files
By geohei in forum Authoring (DVD)Replies: 12Last Post: 21st Mar 2008, 08:57 -
changing video speed with ffmpeg ?
By jdetwile in forum Newbie / General discussionsReplies: 1Last Post: 6th Mar 2008, 15:23 -
Changing speed of movieclip to realtime
By demonwarrior in forum Newbie / General discussionsReplies: 1Last Post: 4th Oct 2007, 09:03
