    Oct 2003
    www.mapquest.com
    I just order'd a 100 pack of Optodisc dvd+r for like 26.00 free shipping @ Supermedia, but my question is that, are these DvD+r by Optodisc any good?
    I last order I purchased from supermedia were Prodisc dvd-r and all came out perfect on my Lite-on812.
    I deceided to try Optodisc due to the sale.
    So what am I getting?? Good, no good? help a brother out!! ?? !!
    Regal-Out
    *New Mac user*, been PC user 4 life
    Avoid.
    Yuck.
    No.
  3. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    I am currently using optodisc with no problems so far. I should say that I burn at the lowest possible speed and don't fill the disc to the edge. I try to set the disc size for 4200. So far no problems but I have only been burning these for about a month. Mabee 20 burns so far but no coasters!
    Donadagohvi (Cherokee for "Until we meet again")
  4. Member 888888's Avatar
    Jan 2004
    Turdistan
    I never understand these kinds of posts. Why do you ask if they are good AFTER you buy them?
    Anyway, after a bad experience with Optodisc DVD-R, I will never touch that brand again. I have never tried their +R but the popular consensus seems to be that they are worse than the -R.
    Personally, I don't see the point of buying those discs. For less than a dime more a disc including shipping, you can get Prodisc which is a much more reliable media. Even if you burner ends up loving these Optodiscs, your chances to start with are better with Optodisc.
    Good luck and make sure to tell us about your results towards the end of the spindle.
    Oct 2003
    www.mapquest.com
    well I went threw about 25 dvd+rs. All dvds burned w/ Roxio was successful, but the speeds from 1-4x kept changeing. Never once did the speed constant.
    I think some did fail while after watching it on my dvd player. Lock up and pauses occured.
    I have used ProDisc -r's and they were very good. I just figure i tried the Opto since they were a steeler price. But like eveyone says, you pay for what u get.
    Do not confuse a "completed" burn with "successful" burn.
    This is probably a bad burn. It does not at all sound "successful".
