After encoding a .vob file to svcd, my video has a little picture of a cube on the top right corner. I figured this was only there since I had the demo, so I registered the software and it was still there. Anyway I can get rid of it?
what do you play with? svcd can look strange with some software players. try media player classic or a software dvd player like powerdvd.
does it look okey if you use the file->preview in tmpgenc when you open the vob and select svcd output ? -
I use Windows Media 10, and I've tried a divx player too with the same result. This appears to me its like a watermark feature on demo version that you have to register the product to get rid of it but I did register it and its still there. It almost looks like a small transparent rubix cube. I do not see it in the preview window though, only during playback after encoding.
The rubix cube is from the mpeg2 decoder(it "decodes" the vob/mpeg2) not from tmpgenc. I think it is from the moonlight elecard mpeg2 deoceder, http://www.elecard.com/products/mpeg2decoder.shtml . Uninstall it and get another one like PowerDVD. You must convert the video again.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 08:57 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
