i was trying to compile my project with dvdlab pro and then at the middle of the process, there was a messege "aborted" and after that the operation was "done".
i looked in my video_ts folder and found out that it was empty.
there was no other "error messege".
how can i solve this?
my video file was a m2v, the audio was ac3 and i added subs and scene selection too if it helps.
(i seperated the audio from the movie).
thanks, and sorry about my english...
Your English is fine, there just isn't much to go on (and it's rude to bump in under 24 hours).
Have you tried to recompile it ? Did it work ?
At what stage did it abort ?
Try killing the movie and reimporting the assets.
Otherwise, check out the Mediachance DVD Lab forums - you may find an answer there.Read my blog here.
DVDLab Pro problem, menu background colors change when rendered.
By PSPGamer in forum DVD RippingReplies: 19Last Post: 2nd Mar 2011, 20:42 -
Problem with subtitles off by default in DVDlab-pro
By blajko in forum Authoring (DVD)Replies: 2Last Post: 6th Sep 2010, 19:21 -
Weird problem importing son format subtitles from TS in DVDLab Pro
By Talayero in forum SubtitleReplies: 1Last Post: 15th Apr 2009, 04:47 -
Subtitle problem with DVDLab Pro
By carlmart in forum Authoring (DVD)Replies: 3Last Post: 21st Nov 2008, 09:18 -
First Play problem in DVDLab PRO
By grzegorz in forum Authoring (DVD)Replies: 5Last Post: 11th Apr 2008, 04:43
