I have the 16x9 selection in the video settings chosen. Whenever I play a video that is 16x9 it plays it as if it's a 4x3 strech. Is there a fix for this?
yeah.. that is only for tvs that are 16:9 if you have a standard tv IE 4:3 then set the dvd player to either 4:3 P/S or 4:3 L/b i would recomend 4:3 L/b for 16:9 movies.. regular F/S movies will then play correctlyOriginally Posted by redskull
I have a similar question... I have a widescreen HDTV set, and am about to get this dvd player. How will it handle 16:9 aspect ratio avi files? Will it display it correctly on my HDTV as if it's an anamorphic dvd, or will it display it as letterboxed 4:3 and thus look vertically squished on my set?
It will display as 4x3 and look squished on your 16x9... you will have to adjust the aspect on your TV
Remote for Philips DVP642
By Melina in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Jun 2010, 22:54 -
PHILIPS DVP642... how do I upgrade the firmware?
By mummer43 in forum DVD & Blu-ray PlayersReplies: 39Last Post: 14th Jan 2009, 19:45 -
Confused by the aspect ratio coming out of my camcorder: 720x480 != 16x9
By kirilius in forum Newbie / General discussionsReplies: 9Last Post: 6th Jan 2009, 15:05 -
Divx Certified dvd player won't recognize 16x9 aspect ratio
By maca in forum DVD & Blu-ray PlayersReplies: 3Last Post: 30th Nov 2007, 13:48 -
Philips DVP642 and DivX 6/Ultra
By cheerful in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Aug 2007, 12:43
