  1. hi
    I need to convert Final Fantasy.avi to vcd with TmpgEnc but it says : "an error occured when audio is decoded"..............;;why??????
    Help would be very appreciate
  2. I had the same problem, solution I used? raise your directshow to priority 1 under options-enviromental settings-vfapi plugin. I found 1(+) to be best since anything higher made encoding slower and divx playback wasnt working correctly (artifacting bad)
  3. what is artifacting?
  4. blockiness (sometimes green)
