I have attempted this with VirtualDub 1.6 - it seems not to be able to get past a problem with a stats file (or a .pass file) which it needs to access after the 1st pass, so as to feed that data into the 2nd pass. I have tried several remedies - such as calling this bitrate curve statistics file .statsfile, or even .pass or, as some have suggested ./pass!!! Getting nowhere ... have used all the How To tutorials to be found on Videohelp.com (i.e. this site ...)
I am capturing from a Canopus ADVC 100 (type 1 DV) and using what is given as type 1 compliant VirtualDub v. 1.6, Win XP, 2.4GHz P4, 1Gb mem, 149Gb HDD
Results 1 to 10 of 10
Sadly, it does not work, and I am so looking forward to making XviD from my Canopus ADVC 100 DV type 1 files! Am I explaining myself wrongly?
I don't think so - after all, I was able to understand exactly what you meantOriginally Posted by Stonechatz
It's something simple, and unfortunately, it's gotta be something you haven't quite got set-up right
Maybe this:
http://www.divx-digest.com/articles/xvid_setup.html
might help ?If in doubt, Google it. -
There are many tools to convert DV Type 1 to Type 2. I recommend using WinDV (http://windv.mourek.cz/download/WinDV-1.2.3.zip) to capture your DV AVI as Type 2, then all your problems are solved.
If you don't need a specific file size try using single pass with target quantizer. That way you pick the quality you want and and every frame has that quality but you don't know exactly how big the final file will be. The results are about as good as 2 pass (at the same file size) but with only one pass.
Type 1 DV AVI files have a single video stream with multiplexed DV audio. A type 2 file has a second copy of that DV audio as an standard AVI audio stream. I know VirtualDub can read the video from both types but I'm not sure it can handle the audio from type 1.
<edit> I just checked -- VirtualDub cannot read the audio from a type 1 DV AVI file. </edit> -
Edit-
Virtualdub experimental 1.6.2 can read the audio from a type 1 DV file. -Edit
Convert DV type 2 to type 1? Or is there an app that will correct sync?
By Colmino in forum Newbie / General discussionsReplies: 7Last Post: 20th Dec 2022, 22:24 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 16:59 -
XviD Quantization type, H.263 vs MPEG; and GMC for hand recorded material
By carlaron in forum Video ConversionReplies: 41Last Post: 2nd Mar 2010, 23:36 -
type 1 or type 2 capture-newbie
By sar in forum Capturing and VCRReplies: 6Last Post: 28th Jul 2008, 19:22 -
DV AVI Type 2 -> Type 1 converter?
By alx3d in forum EditingReplies: 3Last Post: 29th Dec 2007, 21:16
