The video looks great but the audio is like the chipmunks! Tried it several times, rebooted etc. Running 0.0.9q
Thanks for any advice,
Dave
I thought I would try the dvd preset for mpeg2enc but it fails immediately. So i've struck out on both counts.
dave
Encoding started on Mon Dec 13 21:38:11 PST 2004
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
## Component Manager: attempting to find symbols in a component alias of type (regR/carP/x!bt)
usage: movtoy4m -w width -h height -F a:b -a a:b [-s] [-f] [-o ppm/y4m] movie.mov
example: movtoy4m -w 352 -h 288 -F 25:1 -a 4:3 pal_normal.mov
example: movtoy4m -w 352 -h 240 -F 30000:1001 -a 16:9 ntsc_wide.mov
**ERROR: [yuvscaler] Could'nt read YUV4MPEG header!
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
Same thing happens to me :o((
I've a Divx movie with ac3 (a52) 448 Kb/s, 48000 Hz and 5 channels (plus LFE), and when trying to extract only the audio track (I would create a dvd with DVD Studio Pro 3), with every setting I choose (each size of Kb/s, and both ABR, CBR or VBR), but always with the 5:1 channels and 48000Hz options on, the result is a fastfowarded audio file (a 1:51:04 file becomes a 1:31:26 file)...
What can I do mr. major ?
Is ffmpeg able to exctract a 5.1 channels ac3 file ?
Ty in advance!
Strange. What bitrates are you people using? I usually just use the Passthrough function on my AVI AC3s 'cause I usually end up with lower volume when trying to lower the bitrate. Never had the Chipmunks effect though. If you look at A.Pack, which is a pretty good AC3 encoder, you'll find the available bitrates are;
3/2
224-448
2/1
96-448
Try using one of those bitrates. Or just change the Audio Codec to Passthrough. You will have to manually add the .ac3 extension to the output if you use Passthrough. And there aren't any Mode settings in A.Pack, I'd stick with CBR.
I just did a Passthrough then an encode of the same AVI AC3, no Chipmunks, but, I had forgotten about the 'other' objection to re-encoding. I always get lower volume and it also seems that more volume is coming from the right speaker. Do the Passthrough if you want to save the AVI's AC3
high-pitched screeching noise when playing back DVD, but video works...
By xSavant in forum ffmpegX general discussionReplies: 1Last Post: 26th Apr 2010, 18:20 -
High pitched background noise...
By bsuska in forum AudioReplies: 2Last Post: 25th Mar 2010, 13:15 -
Audio slightly high pitched in any player...
By Guitar3dt in forum AudioReplies: 20Last Post: 26th Nov 2009, 18:24 -
DVD audio sounds high pitched
By nopulse in forum Newbie / General discussionsReplies: 3Last Post: 19th Nov 2007, 20:31 -
Music too high and Voices way too low?
By sensesfail86 in forum RestorationReplies: 4Last Post: 8th Jul 2007, 23:08
