im burning vcds. what kind of dvdr cds should i get. please only cds that are sold at best buy
Results 1 to 9 of 9
Look for FUJI packs of CD-R discs that say MADE IN JAPAN. Those are the best you can buy ... anywhere!
Do NOT buy the FUJI CD-R packs that say MADE IN TAIWAN. Those are inferior.
- John "FulciLives" Coleman
P.S.
What I say also applies to packs of FUJI DVD-R discs. You only want the packs that say MADE IN JAPAN."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
what does everyone think about theses dvdr cds? good or bad?
http://www.bestbuy.com/site/olspage.jsp?id=1051384654956&skuId=5222056&type=product -
You want DVD-R not DVD+R unless your DVD burner/recorder is one of the DVD+R only types ... in which case you are screwed!Originally Posted by dblue
i just bought this burner, whitch dvdr would be best for this burner (im not looking for rewritealbe dvdrs)Originally Posted by FulciLives
http://www.newegg.com/app/ViewProductDesc.asp?description=27-152-031&depa=0 -
Taiyo Yuden DVD-R discs are the best. Any FUJI DVD-R package that says MADE IN JAPAN is really Taiyo Yuden DVD-R brand. You can't go wrong!Originally Posted by dblue
The next best and probably just as good are the Maxell DVD-R packs that say MADE IN JAPAN (beware because just like the FUJI brand some will say MADE IN TAIWAN). These are sold at many retail outlets but not at BEST BUY.
If you are willing to buy on-line you can get Taiyo Yuden DVD-R discs direct from this web site ---> RIMA.COM
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 20th Oct 2013, 00:25 -
Longevity of CDs and DVDs? Are my old CDs starting to lose it?
By garybeck in forum DVD & Blu-ray RecordersReplies: 15Last Post: 25th Jan 2013, 14:38 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 14th Mar 2008, 00:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 19:14 -
CHEAP Dual Layer DVDR Blank Disc @ Best Buy: I can't find that thread again
By Scooter_NJ in forum MediaReplies: 9Last Post: 11th Oct 2007, 16:42
