I swear I've searched all over for this. If it's been in front of me the whole time, feel free to flame away . . .
My desired result is a DVD that plays track 1 on bootup and loops it forever. Disc jumps to track 2 with the forward key (>>|) and proceeds to loop that forever. And so on.
Nothing I've tried gives me this kind of simplicity on playback. I can either make something that loops track X without end until you force it into a menu, or it plays through to the end of the disc.
My next attempt was to create a series of useless menu pages with the clips as backgrounds, only to discover that I only get 1 GB for menus on a disc.
I've totally got this with an SVCD (with VCDEasy, methinks), but the quality lacks in comparison and I can only pack an hour into it.
The ONLY buttons that will be available (it's for a kiosk-type thing) will be play/pause, next, and prev. Dagnabbit.
So then, I've got two things I'm asking for. Maybe.
Possibility one is doing it with an authoring package I haven't already tried. I've got access Encore and whatever the Sony/Vegas package is at work, and can beg around (work in a cluster of TV studios) to use just about anything else. Maybe get cracking on scripting?
Possibility two would be maybe force-feeding an SVCD onto a DVD. SVCD's structure with DVD video? Header tricks? I've crammed plenty of VCD streams onto DVDs for Cartoon Network road-trip discs for the young 'un, but this is pushing the specs of anything way past that.
Any ideas would be greatly appreciated. Thanks!
I believe IFOEdit can do it.
I've only read about it, and I'm sure there's people here that are *much* better versed in IFOEdit than I am, so hopefully they interject with the "how to".
Add a post command to title 1 to jump back to title 1, do the same for title 2 .... and so on.
That's the theory ... how you actually do it is beyond me I'm afraidIf in doubt, Google it. -
It can be done quite easy with GUI for dvdauthor if you tweak the author.xml file a little bit...
Assuming your titles have the same properties (resolution, aspect, video norm) you can switch off 'Use titlesets', set 'Start action'='Show movie', 'End action'='Next title'. Drag&drop your titles on the menu background. Right click on the menu background and set 'Pause' to '0' and 'Action' to 'jump title 1;'. Use the 'Create batch' function. Open the author.xml file with a text editor. It should look something like this:
Code:<?xml version="1.0" encoding="utf-8"?> <dvdauthor dest="C:\Filme\Volume1"> <vmgm> <menus> <video format="pal"></video> <pgc> <vob file="C:\Filme\Volume1\MMMenu.mpg" pause="0"/> <button name="MMB1">g1=1;jump title 1;</button> <button name="MMB2">g1=2;jump title 2;</button> <button name="MMB3">g1=3;jump title 3;</button> <button name="MMB4">g1=4;jump title 4;</button> <post>jump title 1;</post> </pgc> </menus> </vmgm> <titleset> <menus> <pgc> <vob file="C:\Filme\Volume1\EmptyBackg.mpg" /> <post>jump vmgm menu 1;</post> </pgc> </menus> <titles> <pgc> <vob file="C:\Filme\Volume1\Film1.mpg" chapters="00:00:00.000"/> <post>jump title 2;</post> </pgc> <pgc> <vob file="C:\Filme\Volume1\Film2.mpg" chapters="00:00:00.000"/> <post>jump title 3;</post> </pgc> <pgc> <vob file="C:\Filme\Volume1\Film3.mpg" chapters="00:00:00.000"/> <post>jump title 4;</post> </pgc> <pgc> <vob file="C:\Filme\Volume1\Film4.mpg" chapters="00:00:00.000"/> <post>call vmgm menu 1;</post> </pgc> </titles> </titleset> </dvdauthor>
Code:<vob file="C:\Filme\Volume1\Film1.mpg" chapters="00:00:00.000"/> <post>jump title 2;</post>
Code:<vob file="C:\Filme\Volume1\Film1.mpg" chapters="00:00:00.000"/> <post>jump title 1;</post>
Code:<vob file="C:\Filme\Volume1\Film2.mpg" chapters="00:00:00.000"/> <post>jump title 3;</post>
Code:<vob file="C:\Filme\Volume1\Film2.mpg" chapters="00:00:00.000"/> <post>jump title 2;</post>
Code:<vob file="C:\Filme\Volume1\Film4.mpg" chapters="00:00:00.000"/> <post>call vmgm menu 1;</post>
Code:<vob file="C:\Filme\Volume1\Film4.mpg" chapters="00:00:00.000"/> <post>jump title 4;</post>
Double click the 'MainBatch.bat' file.
Burn the VIDEO_TS folder like usual.
P.S. Things get a little bit more complicated if you want/need titlesets (this post would just get to long), so tell me if necessary. I will send you the necessary changes for the author.xml file with a PM.
How to Stop Blu-ray Menu Theme Song Looping
By c627627 in forum Authoring (Blu-ray)Replies: 2Last Post: 8th Nov 2010, 22:20 -
looping video for menu
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 23rd May 2009, 07:03 -
Looping Video Multiple Audio tracks
By doctor in forum Authoring (DVD)Replies: 6Last Post: 19th Dec 2008, 10:37 -
Help Neeeded For DVD Project. Extract DVD Menu For Use In Personal Project
By sephiros in forum Authoring (DVD)Replies: 2Last Post: 5th Nov 2008, 12:49 -
Looping DVD with no menu
By SCDVD in forum Authoring (DVD)Replies: 7Last Post: 21st Feb 2008, 20:12
