That would be Math teacherOriginally Posted by offlineAnd my nails are as manicured as my teeth will allow.
Results 31 to 39 of 39
Sad thing is when you get a piece of nail stuck between your teeth. It's hard to get out when it shreds the floss and you can't wedge it out with a fork or a pen................or so I've heard.Originally Posted by northcat_8
Teeth will actually move more than you think. Try pressing the point of a toothpick just below where it is, and keep steady pressure there. Not a lot, just a little, but be patient. You'll feel it slowly working into the gap. After a while, about 5 minutes or so, pull out the toothpick and quickly work out the object before the tooth floats back to its original positionOriginally Posted by Doramius
DAMN IT!!! Now I got a broken tip of a toothpick stuck in my teeth. Thanks a lot CAP!!!!!!!!
Well, at least you stopped worrying about the fingernail. Count your blessings.
Hello. -
Now use a fork to get that damn pick out...
(Stop when you need a crowbar to get the claw hammer out...) -
Are you kidding? He's already moved past those and is up to dynamite and blasting charges.Originally Posted by SquirrelDip
BOOM!
Hello. -
At least now it's something that's biodegradable. The down side is that you'll have to wait 3,400 years for it to either petrify or decompose. But you're not thinking about the fingernail sliver any more ..am I right?Originally Posted by Doramius
Did I forget to mention ...use only plastic toothpicks
I actually use extremely fine piano wire. it's expensive, but it does the job. Even with strong gums, they bleed. My teeth are actually well spaced and fine. the thing I get stuck in them mostly are popcorn seed shells and apple skins. It's not uncommon to find me eating an apple with a knife and removing the skin. I rarely eat popcorn, too.
bash: transcode directly from ISOs using loopback and cat
By diprotic in forum LinuxReplies: 2Last Post: 26th Oct 2011, 15:27 -
Teeth (not Mice!).
By Compo in forum DVD RippingReplies: 16Last Post: 18th Aug 2011, 14:03 -
Cat 1 or Cat 2 HDMI Cables?
By Hal05154 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Jan 2010, 21:25 -
Normal or not?
By alintatoc in forum ComputerReplies: 4Last Post: 25th Mar 2009, 01:36 -
780g MB -> HDMI 1.3b cat 2 -> Samsung LN46A630 = Very fuzzy!
By greymalkin in forum Media Center PC / MediaCentersReplies: 6Last Post: 23rd Jan 2009, 13:04
What the hell is that?
It's not contagious is it
