    Jan 2003
    central NJ
    I am looking for a program that will let me save a particular frame from a video to a JPG file.
    I currently use PowerDVD and I have to keep clicking on a key on the keyboard to save to files on the hard drive while the video is playing. Then I have to go the files and *hope* that one of them is what I want.
    Is there a better way????
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    How are you defining "particular frame" other than clicking a key?
    On Power DVD you can step frame.
    What am I missing?
    PS If your captured video has timecode, programs like Premiere can capture to a frame defined by timecode. Good software will capture +/- several frames so you can choose the best frame.
  3. As you approach the frame you want, put the video in 'pause' mode, step advance to the exact frame you want then capture that frame and 'save as'.
  4. Member edDV's Avatar
    Mar 2004
    technically you will get a better frame cap on the fly for live or interlace tape .
    'step frame' is usually a field only (half vertical resolution)
    a DVD contains info in interlace format.
    a DVD has all the info to construct a full frame. It depends on the player.
    if there is motion between fields, you will see tearing unless motion adaptive processing is applied.
