Hi, my question here is: I got a 512x384 DivX I want to convert to DVD. How do I actually achieve the best results?
It crossed my mind that if I convert it to standard DVD size on TMPGEnc, which is 720x480 for NTSC, the video will actually get worse that it originally is, right? In this case I will be creating more pixels than the original video contains. Shouldn't I just convert to DVD but KEEP the original 512x384 size for absolutely NO LOSS?
Results 1 to 11 of 11
Hello,
Originally Posted by correioelet2002
720*480 full d1
352*480 half d1
320*240 (VCD but upcode audio to 48khz)
Those are it for it to work on a standalone dvd player in dvd format.
The only other option is to leave it in divx and buy a divx compatible dvd player. OR convert to half d1.
Ok, but in my case, should I convert it to 352*480 half d1 to keep it as closer as the original video or converting it to 720x480 is ok?
Is that theory about the image getting worse when making the size bigger than the original DivX? -
You'd probably be better with the 352.480 half d1 resolution. It's a little closer than full d1.
Originally Posted by yoda313If in doubt, Google it.
Mine is, upsizing is bad but downsizing is worse, so always upsize if those are your only choices. Use a nice sharpening resize like Lanczos or Bicubic.
This topic again eh?
Upsizing is the way to go. As I mentioned before I find the BEST resolution for a 512 X 384 avi is to encode at full spec with a video size of 656 X 448 (borders of 32,16,32,16).
Overscan on your TV will make the borders shrink to a negligable (spelling?) size.
Using half D1 is an UPSIZE in the vertical of 25% (compared to my stretch of only 16.5%) and yet a MASSIVE loss when going down of 37% when taking square avi pixels v NTSC pixels into account (and a GIGANTIC drop of 50% after the UPSIZE to 480 in the vertical) compared to my stretch of only 16.5%.
You dont even have to bother doing testing as I'm giving you the answer.
As said above use either BICUBIC or LANCZOS as your resizing filters.
If the half D1 advocates would like to explain their reasoning and which 'incredible' resize filter they use (which stretches and shrinks both at the same time yet gives A1 results), then be my guest.
Oh, and one final point, the last time this topic was posted some bright spark showed a VDub clip resized to 352 X 480 but (doh!) showed an AVI preview and not a mpeg2/DVD resized (704 X 480 4:3) preview......hmmm -
Didn't you post this like 1-2 times already.
My vote: 352x480
If I remember, it came from tv and was compressed to hell with DIVX. No reason to use anything higher than 352x480.Want my help? Ask here! (not via PM!)
I prefer to throw away information rather than let software create it for me. For this reason, I go to VCD (352 * 288) when confronted with this frame size.
*My* personal preference and I've always been happy with the results of doing this, after all, it's a (most likely downloaded) DivX, which is probably questionable in the quality stakes anyway. I've been very disappointed with quality when upsizing using any method, but maybe I need to RTFMIf in doubt, Google it.
Converting DVD's to best quality smallest size video file
By Thunderblaze in forum DVD RippingReplies: 1Last Post: 31st Dec 2011, 04:07 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 11:01 -
Why does XVID avi file balloon in size when converting to mpeg2 or dvd?
By im2020 in forum Video ConversionReplies: 3Last Post: 11th Aug 2010, 12:30 -
Converting mkv to dvd size question?
By riky in forum Video ConversionReplies: 3Last Post: 10th Jan 2010, 07:04 -
Choosing 'best' size of AVI for DVD?
By terrypin in forum Video ConversionReplies: 8Last Post: 25th Jul 2008, 11:42
