Either that or use a different authoring tool ...Originally Posted by bugster
Results 31 to 37 of 37
i replaced audio with mp3 but the file still occupies same size, ulead can replace only with wav or mp3!!! i need a better tool for authoring
Originally Posted by Nilfennasion -
Originally Posted by humbleboy
Also, you are likely to get a better quality video from the 352x480 than you will the 720x480 on certain videos, depending on their length, amount of high motion & movement, etc, when using the same bitrate. Yours is less than two hours so it's not really an issue for you, but on longer videos that are 2.5 to 3 hours or more, you will get better looking results with the smaller frame size using the calculated variable bitrate. I usually go with the 352x480 frame size whenever my calculated VBR falls into the 3500-4000 range, or lower. Full frame encodes at that bitrate usually looks like crap, especially on interlaced stuff where there's lots of fast motion like sports, etc.
HTH"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Are there authoring tools that would be able to create a DVD+R DL version that is compatible with your equipment?
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
Ulead will still encode all mpeg2 before burning, so i took a temp file encoded by ulead , here is the file specifications
http://roblb.com/bitrate.jpg
only this type of files will not be encoded, so i wonder how i should create my mpeg2 so they will not be encoded twice !
thank you -
I agree with Jimmalenko - Dump Ulead for an application that doesn't butcher your (perfectly good?) source files. I suggest a look at TMPGEnc DVD Author.
/Mats
How do i get a 2 hour 43 min video file into 366mb PSP 480x272 mp4?
By DarkShadowRage in forum Video ConversionReplies: 24Last Post: 7th Jan 2012, 20:12 -
So I'm Making a Power Hour DVD...
By Jskot311 in forum Newbie / General discussionsReplies: 2Last Post: 1st Apr 2011, 13:35 -
DVD Power Hour Project Help.
By GlockMasta in forum Authoring (DVD)Replies: 3Last Post: 1st May 2009, 06:23 -
5 hour movie on WMP, 90 min movie on MOVAVI
By jchockey in forum DVD RippingReplies: 0Last Post: 24th Aug 2007, 13:14 -
4 half hour eps on one dvd?
By motleycool in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jun 2007, 23:18
