Hi Guys
I would be so appreciated if someone could guide me about my problem with WinDV. Fist of all I must say that I contacted WinDV's webpage authorities, there was no reply.
I exteremly need your help, please!
When I downlaoded WinDv, for the first couple of times there was no problem at all. I could transfere my DV file (via FireWire cable) from Cam (Sony TRV) to my Laptop (O/S Wind2000, Pentium 4, 2.0 GHz, 256 ram, Built-in FireWire port)
But I did something stupid, and downloaded DV codec files (like AVi codec and Pabasonic Dv codec), still have those codecs on my system. I also downloaded trial version of TMPGEnc softwares to furthure process my AVI files. I wanted to burn a DVD.
Now I can't continue with WinDV. I reinstalled it, but did not work.
The problem is:![]()
When I run WinDV it shows preview movie but as soon as I press "Capture" this error-message appears:![]()
Runtime error! This application has requested the runtime to terminate it in an unusual way. Please contact the application support team for more information.![]()
I heared from someone that upgrading DirectX to 9 could solve this problem, but I tried did not work. It is very difficult to me to reinstall my Win2000 system. Is this the last choice?![]()
Does anyone know how can I fix this problem?
Looking forward to hear from you.
Thanks in advance!![]()
Kind regards,
Hadi -
Thanks for your reply.
My problem was solved just by logging in with another username in my Win2000 system log in.Now: whenever I ganna capture my DV I use that username then it works!!
After transferring my DV I log out again and I use my own username and password to log in. It's funny.Isný it? 8)
Have funKind regards,
Hadi
Runtime error
By alintatoc in forum ComputerReplies: 0Last Post: 20th Dec 2010, 14:19 -
Runtime error
By The Monarch in forum ComputerReplies: 4Last Post: 28th Feb 2010, 02:42 -
runtime error
By ram16 in forum Newbie / General discussionsReplies: 9Last Post: 20th Dec 2008, 22:04 -
Runtime error
By Illusionist in forum ComputerReplies: 7Last Post: 12th Jul 2008, 23:01 -
Runtime Error
By clivedavies328 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 17th Jul 2007, 14:33
