I have used this drive before succesfully. now any disc I rip AND play is not working. the screen is garbled and pink and green ??
the region code is set the rip also has the same issue so does a burned image
whast gives ? I put in a disc I have uccessfully ripped and played before same results so it seems to definately be something with the drive?
suggestions ?
Chris Taylor
http://www.nerys.com/
Hello,
You know that almost sounds like a directx issue I had once. It was something to do with accelerated video or something. I can't remember precisely.Originally Posted by nerys
Do a directx search on microsoft.com for green flashes or something similar and you'll find a few articles on it. Good luck.
Kevin
(PS - is your screen name for nerys from DEEP SPACE NINE's KIRA?????)Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Actually I think your right GOD DAG NAG IT. I deleted 18 hours of working thing it was all bad and it was all FINE rip convert burn was FINE it was only THIS machine when it tried to display the data that it got corrupted. GRRRR 18 hours of work to start all over again :-(
I will look into the directx thing maybe just reinstall it.
thanks !!
Nerys DS9 yes and no. I started using the nick before DS9 but I can not recall where (Discovery channel something) but I did like Kira Nerys so its not a bad connection :-)
Chris Taylor
External Drive Issues
By Squid_uk in forum ComputerReplies: 9Last Post: 18th Aug 2011, 04:52 -
Sony LCD and external hard drive issues
By Mr. Bonejangles in forum Newbie / General discussionsReplies: 1Last Post: 27th Feb 2011, 22:49 -
[WIN7] 64 Home Premium & usb drive issues
By kenmo in forum ComputerReplies: 0Last Post: 3rd Jan 2011, 21:53 -
Cloning a Hard Drive: Regional issues, etc
By dubronidog in forum Video ConversionReplies: 1Last Post: 6th Nov 2010, 13:21 -
Removable hard drive tray issues
By Krispy Kritter in forum ComputerReplies: 5Last Post: 17th Dec 2007, 09:39
