Hi I was wondering if it is normal to see a video that was originally ripped using Xvid codec to have a Divx tag on playback?
If not, is there a way to get rid of the Divx codec tag?
I have both codecs installed Divx 5.1.1 and Xvid 4 Mpeg
Thanks for your help.
You mean it has a DivX tag in the user data or there is a DivX logo on playback? The DivX tag is there if the file uses bframes with packed bitstream. The logo is there if you are using DivX to decode.
For the tag, unpack and remove it with MPEG4 modifier and for the logo, disable generic MPEG4 in the DivX decode options, although that still doesn't guarantee that XviD will be used to decode. Could also tick the don't display logo option or whatever and keep using DivX.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Would synch mostly occur on DVD to DivX, or XviD to DivX?
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2008, 01:01 -
Does divx author reencode Divx and xvid files?
By Onceler2 in forum DVD RippingReplies: 4Last Post: 26th Aug 2008, 18:16 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25
