Hi there i downloaded the TMPGEnc DVD Author and had some mpg's on my computer but really would like to know what program can i use to convert divx or xvid avi files to mpg so that way the TMPGEnc DVD Author can handle them and i can use that program for the files it was ment for.
Results 1 to 14 of 14
TMPGEnc Plus, CCE, Mainconcept .... there's any number of Dedicated MPEG Encoders around. I use TMPGEnc Plus, BTW. If you want quick n easy (at the expense of control and options), you could try the All-in-one tools listed here.
If in doubt, Google it. -
Well im new to this so for now a program that will do the work for me.
Originally Posted by freestylegreek
I'd suggest that you follow the All-In-One tools list that I linked to above, and select a couple of the tools in there, read the user comments, maybe download a couple and give them a go. Don't forget to look for any guides for the tool in question (listed just above the user comments).
In the past I've used DVDSanta, NeroVision Express, TheFilmMachine and WinAVI Video Converter, so from my point of view, naturally I'd suggest you research these first, as I can vouch for them being pretty easy to pick up.If in doubt, Google it. -
I happen to get dvd santa but it didn't do its job. What i want is a program that will put an avi such as divx of xvid into mpeg format so when i use TMPGEnc DVD Author i can select this mpeg file and put it into the program to work.
didn't do its job? what didn't it do? please explain and it is much easier to help.
And test more than tool one...jimmalenko has mention several. -
It basically made it into dvd format which i dont want. I was really looking and hoping it will put it into mpeg mode.
I check the rest out too.
Thanks. -
Even though you've got IFOs, BUPs & VOBs from DVDSanta, you can still import these straight into TMPGEnc DVD Author - just use the Add DVD Video button instead of the Add File button
Ahhh ok then i got what your saying. I didnt know you can do that. I was just thinking mpeg format.
Thanks once again. -
That's also true cause im new to this and i dont want to spend hours on doing different things.
I need a free program that would convert my Dvds into XviD or Divx
By babeflover in forum DVD RippingReplies: 9Last Post: 22nd Apr 2012, 07:05 -
Convert WMV to AVI / DivX / Xvid
By p_uriel in forum Video ConversionReplies: 5Last Post: 14th Feb 2010, 21:40 -
What program gives the best quality results, when converting AVI/DIVX/XVID
By Rockstar452 in forum Authoring (DVD)Replies: 3Last Post: 3rd Dec 2007, 01:19 -
Can you convert an AVI encoded with Xvid to one with a Divx codec?
By Timfoxx in forum Video ConversionReplies: 3Last Post: 6th Aug 2007, 22:53 -
I need to convert dvd into avi!not xvid or divx!
By picky2112 in forum DVD RippingReplies: 5Last Post: 6th Jul 2007, 02:22
