  1. i have here a dvd, region 1 of the craft, which starts with a very anoying dvd demo. i like to change that so that the movie starts right away. the problem is that this demo is the first chapter of the movie and the movie itself starts at chapter 2. now my question is what i have do so that the dvd starts with the movie at chapter 2?
    the other problem i have is with the region 3 dvd of dracula 2000. the audio is out of sync and i wanna change that if it's possible. so my question is how i add a delay for the audio or video with mydvdedit so that audio and video of the movie are in sync again?
    thanks for helping
  2. You cant do that with myDVDEdit.
    The actual version cant change any stream data, only informations in the IFO files.
    To do what you want to do, extract the audio and the video stream (many tools for that). Correct the sync with Quicktime Pro, and than rebuild un new DVD with a tool like MovieGate. You will lose the menus, but it's the only solution I know.
    Jérôme.
    myDVDEdit, the DVD resource editor.
    myDVDEdit, l'éditeur de ressources du DVD.
