do you any software that can make autorun in VCD...
my plan is to include a media player or movie player in my VCD so when i insert the VCD in my PC it will play the movie using the media player or movie player in my VCD not the software installed in my PC
i've seen this done in some commercial VCD but i don't know how to do it in my burned VCD...
or any program that can auto run any executable programs in my burned VCD?
hacking the Net using typewriter :D
I've got all the files already set up to do this using media player classic - Do you want a menu in a html file (displayed on insert), or do you just want to start the movie ?
If in doubt, Google it. -
both so ill see which one i like best
hacking the Net using typewriter :D -
Done.
Autorun with Menu
Autorun Movie Only
Burn the files as data CD.If in doubt, Google it. -
thanks a lot ill try these later and experiment on it...again thanks a lot
Autorun Powerdvd in MCE2005
By alucard2050 in forum Software PlayingReplies: 0Last Post: 23rd Feb 2010, 20:30 -
software recomendations to make an autorun CD
By julitomg in forum ComputerReplies: 2Last Post: 23rd Jun 2008, 16:46 -
Autorun Precedence - DVD & Autorun on the same disc
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2007, 21:26 -
How to make an autorun VCD in English please!
By jimiir in forum Authoring (VCD/SVCD)Replies: 10Last Post: 8th Aug 2007, 23:56 -
DivX on DVD Autorun Software
By Burgos in forum Software PlayingReplies: 0Last Post: 31st May 2007, 10:13
