I have a few Video CDs that i'd like to put onto a DVD-R and have them play as if they were a normal DVD. But i don't feel like spending hours upon hours, doing all kinds of research, reencodeing, transcodeing, resizeing and all that other crap.
Are there any simple 1-click type programs out there that will save me the headaches, do all the work and put the VCD files into DVD format, to later be burned in a program like nero?
Results 1 to 30 of 31
After actually doing all those hours upon hours of research, I can confirm right now that you don't need to re-encode, transcode, resize or do any other crap to a VCD to get it playable on a DVD ...
... But if you'd taken 5 minutes to look at the stickies, or done a forum search, you might have found this one
Extract the MPEG out of the DAT files using ISOBuster or VCDGear. Drop the MPEG files into TMPGEnc DVD Author, and it'll do the rest.
Not 1-click, but not rocket science either
If in doubt, Google it. -
That's 2 clicks.Originally Posted by jimmalenko
"Art is making something out of nothing and selling it." - Frank Zappa -
Search is your friendOriginally Posted by Star Warrior
I find both ISObuster and VCDGear easy to use, especially when there's this guide for ISOBuster
TMPGEnc DVD Author cannot convert PAL to NTSC - there's a few guides here on how to do it - but I don't think they'll be for you
I think theres a mpeg encoder on Nero that has the Pal/NTSC option. Could i use nero to convert it to NTSC?
Its just a simple few clicks though,not a whole lot to think about, and worth the encodeing time if the results are good....Originally Posted by jimmalenko
But i want you to tell me!! You have all the answers!!Originally Posted by jimmalenko
OK, fine.Originally Posted by Star Warrior
IMHO, Nero's encoding engine is sub-par, to say the least. I believe in using dedicated tasks to do dedicated jobs, and Nero's all-in-one NeroVison Express just doesn't cut the mustard IMO. PAL/NTSC conversions are difficult at the best of times, and given that we're talking about VCD sources, I can only assume that the sources for them were downloaded, which means they were probably lacking in quality to start with. If the source was DVD, you'd just do a DVD to DVD backup, wouldn't you ? At the very least, you'd do the PAL/NTSC conversion using the DVD as source, anyways.
The ISOBuster/VCDGear & TDA method that I mentioned above is IMO the fastest/easiest way to do this. As for PAL/NTSC, it's not a drama for me as I have a multisystem DVD Player and TV. Maybe you should investigate this possibility also, or put up with (IMO) sub-standard results from NVE.If in doubt, Google it. -
Mustard aside, nero should be fine for his purpose. If the sources are VCD to begin with, what's the point of trying to use some higher quality method dump them to a DVD?
The method was the TMPGEnc also works decent too apparently. Now my only problem is the VCDs are in pal and i need to convert them to NTSC. Burning under VCD in Nero with the NTSC option checked does not seem to do anything.Originally Posted by stillmars321
Got any other ways to convert Pal to NTSC? -
Also would converting a Pal DVD to a NTSC DVD be any easier than converting a VCD?
I was able to get it onto a DVD just fine, now its only the Pal signal stuff i have a problem with. Any help would be appreciated. -
Did you read any of the guides at the link I posted earlier ?Originally Posted by Star WarriorIf in doubt, Google it.
hey jimmalenko,i need to go to the toilet and take a dump,would you wipe my ass for me.?
as i cant be bothered going through the motions of ripping off a piece of toilet paper,and wiping my own ass.its just too bothersome.
roflmao.
you should also re-encode the audio from 44000 to 48000 to make the vcd a dvd-compliant mpeg 1
member since 1843 -
TMPGEnc DVD Author takes care of that little problem automaticallyOriginally Posted by ricky1756
But I will have to wait minutes for it to download !Originally Posted by jimmalenko
When I put all my VCDs on DVDs I found that have to resample the audio really slowed down DVD Author, and about 1 out of 3 times it would hang up after working 15-20 minutes.
For me it worked much faster to change the audio in TMPGEnc Plus or Goldwave first. -
I have no such hanging up issues with TMPGEnc DVD Author and have managed to create DVDs (so far) using VCD as source for up to six hours long (so far). True, it slows things down, but I put that down to encoding alot more video than usual.Originally Posted by BobK
@ jimmalenko
You have the patience of a Saint.
Cole -
Awesome! I just downloaded the regular TMPGENC and simply re-processed/encoded the VCD files, under VCD NTSC mode at default settings. In order to change the files from PAL to NTSC.Originally Posted by jimmalenko
I was reluctant to resort to this because a few years ago when i had my old Pc, a 1.3Ghz celeron 128K L2 Cache , it would take FOREVER to do ANYTHING in TMPGEnc.
However my new Pc, a 2.8Ghz Celeron D with 256K L2 Cache, went pretty quick. Only took about 15-20 minutes to encode each hour of video.
Once i was done with my new set of NTSC VCD files, i processed it again with TMPGEnc DVD Author and then burned with Nero. The end result was good and i sucessfully put 8 VCDs onto 1 DVD-R! (Still had almost 2GBs left over btw)
Thanks!
Simple 1 click DVD to AVI application ?
By mpoirier in forum Video ConversionReplies: 19Last Post: 28th Apr 2011, 18:08 -
Printing multiple DVD covers with one click - not 22 clicks
By bryankendall in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2009, 10:09 -
Power DVD - no 'click slider' in version 7?
By terrypin in forum Newbie / General discussionsReplies: 6Last Post: 6th Jul 2008, 12:28 -
Toast 9 & HD-DVD- once ripped under PC, a one-click encoding option?
By broaddd in forum MacReplies: 0Last Post: 28th Mar 2008, 19:43
