i have a big problem here. Ok i have an mpeg1 movie that has dual-language. and during the movie it plays both simoutaniously. One language out the right speaker, different language out the left speaker.
Is there a way filter out one of the language?
Ok to make things more clear, it has chinese and vietnamese. i want only vietnamese. In TDA, i can choose stereo setting, which will encode with both languages. Or i can choose Bilingual, which encodes just vietnamese.
I dont know why I couldnt choose. it basically determine which to filter out, and happens to filter out the language i need. If anyone know of anything that can help, im all ears.
ohh thanks! although that will set me back a week or two but thanks for guiding me you super freak
do you have any suggestions on which softwares to used to do it with. i know i can demux it with tmpenc. and itll be mp2. but im at a dead end there.
What software do i use to: convert to wav, delete channel, set as mono, and finally convert to mp2? -
that will enable both languages.. but when you play the dvd ..just select Audio to pick different language.. the default language is the Left Track.. so, if the left track is all your want. you wouldn't notice the 2nd lanuage at all
if you don't like it.. too bad.. there are lots of work to "delete" the 2nd track..
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 02:26 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Bilingual VCD plays both languages in Media Player Classic!
By cordeliamars in forum Authoring (VCD/SVCD)Replies: 2Last Post: 27th Aug 2007, 12:25
